Helo Ivor bach!
SillyBilly
Helo Ivor bach!
Post by SillyBilly » Tue Jul 08, 2008 10:04 pm
As per title a 45mm version of the Locolines Ivor kit, sat on 32mm track. Just thought you'd like to see it! Note I have added cylinder detailing on the front end of the frames.
mhlr
Re: Helo Ivor bach!
Post by mhlr » Tue Jul 08, 2008 10:08 pm
SillyBilly wrote: As per title a 45mm version of the Locolines Ivor kit, sat on 32mm track. Just thought you'd like to see it! Note I have added cylinder detailing on the front end of the frames.
Nice one Mr. High!!! Der der derduler der, der de derduler der der.... etc  :lol:  :lol:  :lol: I see you used the spare so called "GWR paint" spare from you Edrig! Will make a nice attraction to the shop!
SillyBilly
Re: Helo Ivor bach!
Post by SillyBilly » Tue Jul 08, 2008 10:10 pm
mhlr wrote:I see you used the spare so called "GWR paint" spare from you Edrig!
No its some southern stuff which is recomended, a frined is also building one so I just had a small sample off him.
riveresk
Post by riveresk » Tue Jul 08, 2008 10:21 pm
Nice 'un. My brother offered to buy me that for my 21st birthday - so that he could build it. I declined much as I love Ivor the Engine. I offered to go Dutch on it with him though. Both saving up the money. Just a shame that both my Bluebell and Idris toys are too big for the scale. :cry:
Post by laalratty » Tue Jul 08, 2008 10:29 pm
As my sister has aluded to- I want one! looks great! Thats going to look interesting with the model Pickering carriage on the WHR shop railway, or have you opted to get the cardboard carriage kit off the locolines website
SillyBilly
Post by SillyBilly » Tue Jul 08, 2008 11:09 pm
The link doesn't work, probably run it with the VofR van I built.
Post by Chris Cairns » Wed Jul 09, 2008 11:41 am
I'd be interested in your views of building this kit, as I got one at Merstham but it is 2nd in the queue after the Wickham I've just started.
I'm not impressed with the quality of the resin castings, and I only got one buffer beam lamp (as currently shown on his website & instructions illustration). The pipe for the boiler has actually been roughly cut and is actually less than the 80mm length required. How easy is it to sand the chimney & steam chest to fit the boiler? What paint did you use as it looks a bit off colour?
Any reason for not fitting the cab steps?
I've downloaded the instructions & jpegs for the free coach kit (upper case F required in URL). If you PM me your e-mail address I'll e-mail them to you. I've had problems accessing the Locolines website some times, and indeed it was unavailable as I started typing this, and is now available again including the free coach web page.
As I'm sure you are aware Rob Bennett has produced Edwin Jones the Steam that comes with the kit, Dai Station, Idris the Dragon & Evan Evans the Song (although not updated on his website yet).
riveresk
Post by riveresk » Wed Jul 09, 2008 3:49 pm
I want that Idris *pouts*.
Post by Chris Cairns » Wed Jul 09, 2008 4:08 pm
I want that Idris
Available from here - http://www.7-8ths.info/busybody/Ivor.html I think he was selling them painted for £5.00 at the recent Merstham show.
It is just a pity that you have to paint Edwin Jones the Steam as he was painted on display on Rob's stall.
MuzTrem
Post by MuzTrem » Wed Jul 09, 2008 4:20 pm
Nice work there Billy :D I like the extra underframe detail and paitned wheels, they make a big difference to the overall appearence - for me, one of the big drawbacks to Locolines kits its that they rely on IP chassis, which weren't really desinged for steam locos and, IMHO, just don't look right under them in most cases... :cry:
riveresk
Post by riveresk » Wed Jul 09, 2008 4:34 pm
CCairns wrote:
I want that Idris
Ta, *goes off to have a look*.
Post by Chris Cairns » Wed Jul 09, 2008 5:11 pm
Actually this kit, and the Wickham as well, use a motor mounted with a plastic gearbox, and the chassis is 2 sides of a plastic strip which needs cutting to size and drilled for 2 axles, and is held together with cardboard spacers. Steel wheels are provided with Ivor (plastic with the Wickham) and the kit includes decorative wheel trims for Ivor. So it is not an IP Eng chassis used. Looks like William has painted the wheels black, Locolines has painted theirs green on the website & instructions illustration.
MuzTrem
Post by MuzTrem » Wed Jul 09, 2008 5:42 pm
I meant Locolines kits generally rather than specifically the Ivor; the IP chassis is reccommended on their site for Prince, Tiny and the Quarry Hunslet kits.
made-in-england
Post by made-in-england » Wed Jul 09, 2008 6:32 pm
pssssshhhhtiicufffff
" Up in the top left hand corner of wales there was a railway. Not a very long railway, or a very important railway! but its all there was!"
SillyBilly
Post by SillyBilly » Thu Jul 10, 2008 7:01 pm
CCairns wrote:I'd be interested in your views of building this kit.
They will be available in a forum 'article' to be written in the future. Although to save you agro with your 32mm gauge chassis I shall post the following.
"I made my chassis spacers from the off cuts of supplied to different dimensions of the 32mm ones supplied, I also made some different gearbox spacers from cereal box card so that the gearbox sides were flush with the motor, using the card supplied for this job made the frames to wide apart for 28mm back-to-backs and the trolley failed the points test as well as being a bad runner due to the wheels rubbing on the frames."
I posted this on the G Scale Mad forum
CCairns wrote:I'm not impressed with the quality of the resin castings, and I only got one buffer beam lamp.
They are suppose to have a 'Cartoony' feel, a bit iof filling won't do them any harm. I got two lamps, I fitted two lamps!
CCairns wrote:How easy is it to sand the chimney & steam chest to fit the boiler?
A loooong job, do it outside with a dremel and wear a dust mask, it really stinks and is VERY dusty.
CCairns wrote:What paint did you use as it looks a bit off colour?
And that's after I added some white, the paint is recomended in the instructions, I'm building this one and a friend is also in the middle of one, and he bought some paint so I just had a sample.
Yes, I forgot!! Now fitted, I have put a toggle switch in one of them to replace the rubbish switch supplied.
Post by Chris Cairns » Fri Jul 11, 2008 10:41 am
Thanks for your prompt replies William.
I intend making a rolling chassis for my Wickham, using the supplied plastic strip plus some plastic from old CD cases. Unlike Peter Longfils' Wickham, I intend to fit the motor upright, but the seat bottom will need cutting out first as this rolling chassis will be complete with the battery box. I've also got a toggle switch which will stick up through the control panel and look like a gear change/ direction change lever.
Once I've sorted this out for the Wickham, I'm sure I'll do something similar for the Ivor.
Thanks for the warning about the wheel spacing, will look at that very closely before glueing up!
SillyBilly
Post by SillyBilly » Sat Jul 12, 2008 6:14 pm
"In the top left-hand corner of Porthmadog shop, there is a railway. Not a very long railway or a very important railway, but it is called The Shop Railway, and it is there."
Launched! Has hauled many trains today, already 3 members of the public have commented on how much they like it!
Post by Chris Cairns » Sat Jul 12, 2008 6:44 pm
Great Stuff William, and a very appropriate setting.
But where is Edwin Jones the Steam - off for a cup of tea, talking with Dai Station, listening to Evan Evans the Song, or is he looking for Idris the Dragon? Poor Ivor must be lonely without them!
Matt
Post by Matt » Sat Jul 12, 2008 6:50 pm
Nice photo, and nice idea.
SillyBilly
Post by SillyBilly » Sat Jul 12, 2008 8:00 pm
I don't feel confident in painting him so it is going to be done by a fellow WHR volunteer, soon I'm hoping.
