Millie as Prince?
RuneK
Millie as Prince?
I'm watching my bog standard Millie, and wonder if there is any problems related if I want to make it into a Ffestiniog "Prince"?
Will the heat from the burner be a problem for the closed tank?
Can I use car paint and primer from aerosol cans?
Have somebody here tried this conversion? I have found a picture of what looks like it, but it could have a Bertie underneath. I don't know.
Where do you get brass material for DIY projects?
RuneK
- JMORG
http://www.lightline16mm.com/prince.html
The bodywork for bertie is easy to take off, so adding a new bodywork shouldn't be much of a problem.
Rattle can paint will be fine, use an etch primer on brass, I might be tempted to use enamel spray for anything that will get very hot particularly if use a pot boiler as your base loco.
If you want to paint it red be aware that red can be quite a thin colour (it doesn't cover very well) and you may need more than a couple of coats.
Use good sprays from a motor factor or even Halfords, random tins from the local market or pound shop can be difficult to colour match later on. Believe it or not there are many different shades of Black!
I always use white primer if I'm going to paint something red or yellow (my last tin of yellow was 'orribly thin) and it does help to get a better colour more quickly.Big Jim:108597 wrote:If you want to paint it red be aware that red can be quite a thin colour (it doesn't cover very well) and you may need more than a couple of coats.
RuneK
- Keith S
- dougrail
Beware of brass.
I used Plastikote 'Super' primer and 'Super acrylic paint on a custom tender I had built. Smooth, convincing paint job. However very delicate,The primer had not bonded to the metal at all. What it had created was a 'skin' made up of the dried primer and then the paint - an elasticlike skin which although tight on the metal, was very easy to peel off like rubber or skin as it had not actually clung to the metal.
Rattlecan wise, U-POL Acid Etch No.8 primer [plus goggles and a respirator with an A2 filter] are your best bet.
I got as far as laying a 16mm drawing of an FR England over the top of the drawing of Bertie's working bits, available from the RH website, and it's remarkably close, as long as you allow the boiler to fill the saddle tank - as Bertie's does. I think you could achieve a scale height if you allowed the upper part of the front of the cylinders to project up through the running plate under where the sand boxes are, but I think the real thing has a square-ish protusion there anyway. And if you go for a "large" England, rather than Prince, then the wheels aren't too far off...
It was an exciting daydream, but I'm afraid although I possess a Bertie I lack the metalworking skills to make it anything more than that for now. I might just add a tender and some sandboxes to my Bertie and paint it lined FR maroon...
Good luck with whatever project you decide on,
Alan P
GardenRail
Re: Millie as Prince?
RuneK:108570 wrote:I'm watching my bog standard Millie, and wonder if there is any problems related if I want to make it into a Ffestiniog "Prince"?
Bit difficult given that Millie is a potboiler. This, I suspect is why the conversion was done on Bertie
RuneK
bessytractor
