Brandbright panelled coaches
- paullad1984
Does anyone have/run brandbright panelled coaches with:
a) An Accucraft Caledonia?
b) IP engineering freelance wagons?
I have an idea in mind, but want to know how they look together?
- paullad1984
steamie1
I know how you feel.
It's the beauty of the shows, being able to see things together. I have Accucraft rolling stock and often it is too wide. Now I think I will flog them off.
I have a Tom Rolt and will now try to build an Atropos coach from the Corris stock because of its size in relation to the loco. It's good to get the height and width right or else you can soon go off the beloved new coach or truck.
- paullad1984
was toying with seeking out a 2nd hand caledonia, using brandbright pannelled coaches with IP wagons....
Had also mulled over fitting bigger wheels to the stock to bring height up....
I understand the couplings on the caledonia/IOM bey peacocks are higher than is normal for 16mm due to they're different scale?
steamie1
https://www.youtube.com/watch?v=__BL5rBpm-s
Is there anything on You tube that will help? Just an idea......
- paullad1984
- paullad1984
steamie1
