IP Engineering Speed Controller Max Voltage
Hope Mountain Railway
Post by Hope Mountain Railway » Mon Aug 11, 2014 4:12 pm
Hello All,
I've wired in an IP Engineering speed controller into an Essel Chassi'd Freelance Diesel outline Tram loco. I have a very suitably sized battery pack an charger from a cheap R/C Tank available to use. However it is 9.6v 1000mAh. Would this be too much for the Transistor in the kit. The Instructions I have don't mention Max Voltage. The Chip is bolted to some brass sheet, part of the bodywork, as a heatsink. Hope someone can help, Thanks.
Enginehouse
Re: IP Engineering Speed Controller Max Voltage
Post by Enginehouse » Mon Aug 11, 2014 7:41 pm
Hope Mountain Railway:103215 wrote:Hello All,
Either ring Ivan (IP Engineering) or alternatively look closely at the tranny and quote the number of the device. Then look it up on the net and the data sheet will provide all of the information that you seek and probably more. If the item is current stock either approach should do the trick.
Chip Spec
Post by Hope Mountain Railway » Mon Aug 11, 2014 8:52 pm
Hello Roy for , thanks for that , I have rung IP, went to answer. Also sent an email. Will look at the chip. Gareth
Users browsing this forum: No registered users and 44 guests
