IP Engineering Jane burner
Paul H
Post by Paul H » Wed Jan 29, 2014 11:08 pm
Greetings,
Does anyone know if the meths burners on IP Janes were soft or silver soldered?
Thanks,
Paul
Post by Big Jim » Thu Jan 30, 2014 2:56 am
I think mine was silver soldered but I stand to be corrected.
Post by MDLR » Thu Jan 30, 2014 1:07 pm
If it's anything like the Roundhouse ones, the main tube and wick tubes came as a silver soldered assembly, but the meths tank and filler pipe were soft soldered. I know - I built the kit!
Paul H
Post by Paul H » Fri Jan 31, 2014 5:57 am
How about the overflow, Brian? I have been asked to sit an overflow to a Jane and would prefer not to have any surprises whilst working...
INJIN
Post by INJIN » Fri Jan 31, 2014 8:54 am
Paul, You could always re-make the burner. good practice for the Irish engine!
Turn the wick tubes from brass bar & bore them out. Fabricate the tank from 0.5mm brass sheet. some 1/8th pipe for the wick tubes to attach to. Silver solder it all together & you'll never have a problem.
Keith
Post by MDLR » Fri Jan 31, 2014 1:02 pm
Paul H:96297 wrote:How about the overflow, Brian? I have been asked to sit an overflow to a Jane and would prefer not to have any surprises whilst working...
The overflow was soft soldered too, as heat from the burner never got anywhere near it!
Paul H
Post by Paul H » Fri Jan 31, 2014 4:31 pm
Keith,
It would be great practice for a certain Irish model...
Unfortunately, this is a new, old stock Jane from one of the first two batches that a friend is just itching to run. He bought it three weeks ago at the big steamup in Diamondhead, Mississippi and it made an express trip to the (carpeted) concrete floor on its third run ever. I have had it stripped down to straighten the bent frames and bodywork, which I am pleased to say has been a complete success. It once again sits square on a piece of glass and runs really smoothly. Hopefully I can fit the overflow tonight and then redeliver it tomorrow.
Paul
