Sealing between the reverser valve and the frames on Mamods
alan2525
Post by alan2525 » Sat Aug 09, 2008 12:08 am
With the Mamod loco's the cylinders have a nice thick gasket between the cylinder and the loco frames, however the reverser valve just mates against the frames. Once running it's not normally a problem with steam leaks here if the screws are tightened but could a gasket material be used on this surface to prevent any leaks?
If so what would be the recommended material?
Alan
ACLR
Post by ACLR » Sat Aug 09, 2008 12:26 am
I havent put a gasket there and have not any leaks but im guessing you could use some kind of liquid gasket cement there instead of a paper gasket
Post by Chris Cairns » Sat Aug 09, 2008 9:51 am
These gaskets were actually fitted to the IP Jane, and I now use them on my Mamod rebuilds as well. I've tried liquid gasket before but it does not work very well.
I use 0.5mm Flexoid Oil Resistant Jointing Gasket which was off ebay ( http://cgi.ebay.co.uk/Flexoid-oil-resis ... .m14.l1318 ).
I sent some to mhlr to fix South-Trethevy's leaking MSS that was on loan there.
SillyBilly
Post by SillyBilly » Sat Aug 09, 2008 3:04 pm
It would have to be a very fine gasket, otherwise you'd end up with the frames to wide apart. In the past I've just used some sealent (black stuff) that was at the FfR.
