coal fired mamod.
Matt
coal fired mamod.
I've just had an interesting thought. You know that the mamods come with a soild fuel tablet tray which is useless as the pelets are useless so you through it away and replace with a meths burner? Well, why don't they keep the tray, and replace it with broken up coal?
Think about it. It'll be more realistic thatn meths or pelets, it'll produce more heat than meths or pelets, and will last longer that meths or pelets with attention needed.
It may sound a little crazy, but it might work. whats your view?
SillyBilly
Matt
well, the bottom of the mamod is pretty open, so all you need to do is get one of those hand head fans you can get from a gift shop, hold it above the boiler, pointing away from the boiler to create a draught, untill you've got pressure up, and bob's your uncle! Besides, you need a good strong draught if you've got internal firing about trying to make 40 to 60ppsi, whilst with a mamod your making only 20ppis.
- andysleigh
Matt
- andysleigh
South-Trethevy
MTA
With a TE1A, if you used the bottom of the frebox then that has a large 'grate' area than that of the two tiny compartments in a solid fuel tray used by Mamod loco's.South-Trethevy wrote:I ran mi TE1A on Charcoal n it worked fine... i dont c Y an SL1 wont do the same!!!Matt wrote:OK, if somes tried it, and it dosn't work, I take it not to try it out.
Plus, charcoal burns more easily than coal...
SillyBilly
Eh, how is that going to work? It'd just create a warm breeze smelling remotly of coal.Matt wrote:pointing away from the boiler to create a draught
Are you insane? You have to maintain a strong draught or the fire just dies!Matt wrote:Besides, you need a good strong draught if you've got internal firing about trying to make 40 to 60ppsi, whilst with a mamod your making only 20ppis.
Hancockshire
SillyBilly
ptlrcecil
Chris
- andysleigh
i dont think such a thing would be impossible.
But it would be quite hard to do, and fire.
You can avoid the back axle by bringing the firebox right back into the cab. Like DJB did on the edrig. This would give good firebox room.
Another option would be to use a marine type boiler, like on the bagnall saddle tank locos. This may just about clear the rear axle.
Chris
Indeed I'm sure that you can make something that would work, but not just putting coal into the mamod solid fuel burner.andysleigh wrote:i dont think such a thing would be impossible.
