annie's new chuff pipe
andysleigh
Post by andysleigh » Wed Apr 09, 2008 8:06 pm
mhlr
Post by mhlr » Wed Apr 09, 2008 8:32 pm
I saw it, SOUNDS FANTASTIC!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SillyBilly
Post by SillyBilly » Wed Apr 09, 2008 10:27 pm
I have my order placed :D .
mhlr
Post by mhlr » Wed Apr 09, 2008 10:28 pm
cheers to andys new busiuness! :D
andysleigh
Post by andysleigh » Wed Apr 09, 2008 10:31 pm
Boilertite loco works
now taking orders
andysleigh
Post by andysleigh » Thu Apr 10, 2008 12:57 am
nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
oooooooooooooo
ooooooooo
oooooo
ooo
o
annie fell off the table, (thanks to dog for bumping the table) , the bunker is bent, but thats the only damage i can see hopefully.
what to do
repair the old one
or make a new more real one.
mhlr
Post by mhlr » Thu Apr 10, 2008 1:11 am
ROFL I AM A WITNESS!!!!!!!! ANDY PUT ME ON WEBCAM WEN IT HAPPENED ROFL!!!!!!!! :lol:
u will repair it
DW
steamyjim
Post by steamyjim » Thu Apr 10, 2008 9:55 am
Sounds brilliant Andy!
SillyBilly
Post by SillyBilly » Thu Apr 10, 2008 4:38 pm
Oops, you could always but a flat back cab on it. But you'd have to give the loco a full re-paint.
andysleigh
Post by andysleigh » Thu Apr 10, 2008 4:42 pm
its ok now.
dad bent it back into shape.
altho, i may make a flat back , as the bunker makes it hard to attach coplings
mhlr
Post by mhlr » Thu Apr 10, 2008 4:57 pm
steamyjim wrote:Sounds brilliant Andy!
WTF Jimbo?!!!!!
SillyBilly
Post by SillyBilly » Thu Apr 10, 2008 4:57 pm
Therewas a How To thing on the Chidham site, but that's gone now. You could ask Keith for it.
steamyjim
Post by steamyjim » Thu Apr 10, 2008 5:16 pm
WTF Jimbo?!!!!!
The chuff pipe
Post by Chris Cairns » Thu Apr 10, 2008 9:50 pm
A very interesting and nice sound Andy. Do you use a small circular hole or a slot to achieve your chuff? I'm currently using a piece of copper pipe which is soldered up on the top, and a small circular hole drilled on the side lower down, to put on top of my Mamod & IP Jane exhaust pipes as an exhaust restrictor, and was wondering if a small horizontal slot would make a difference to the chuff achieved.
Your experience just proves that live steam models should be kept away from animals and inquisitive young children, otherwise accidents will happen.
andysleigh
Post by andysleigh » Thu Apr 10, 2008 10:19 pm
i use a large slot.
but it needs some work , after running it on the club track, i found that it wont keep the deep sound for very long, it will then change to a high sound. which i dont want. i think i bigger piece of pipe is needed.
MARK PULLEN
New User
New User
making chuff pipes,
Post by MARK PULLEN » Wed Jul 09, 2008 9:30 pm
On roundhouse loco,s take a bit of brass about 1/2 inch long drill two holes in the bottom of it to take the two 1/8th exhuast pipes,in the other end of the brass drill a bigger hole until you see the two holes,i then turn some brass to fit in the larger hole i drilled,i then drill a small hole through that straight down the centre,the exhuast then shoots through the small hole making a blast,this is then directed to hit the chimney base giving a chuff,it's a blast nozzel,as full size.
On accucraft loco,s
you have a single exhuast pipe,you can shorten it into the smokebox then cut a thread on it take a piece of brass ,drill and tap this to the same as the exhuast don't drill all the way through the brass,because you need to drill a small hole from the top,this then gives you a blast pipe,which give you a chuff.
