A Forum Project locomotive
- Dr. Bond of the DVLR
- Retired Director
All came from an Idea of Dan's of an relatively simple to build first locomotive to have a go at. It uses really simple boiler, cylinder arrangement and burner making it an excellent locomotive to have a go at. I have so far only got the frames on mine made as I am waiting for a set of wheels to arrive! Mine is 45mm gauge and to a slightly different designs to Dan's but still mechanically identical showing the versatility of the design. Dan's is 32mm gauge. I want to make mine as simple and easy to construct so am buying the difficult to make bits, Dan has made all of his. Now over to Dan...
- 90733
DLRdan
Thanks Zach. My loco is based on the scotish gas works locos made by Kerr Stuart and Barclay to name a couple, pictures can be found on the Talyllyn museum website and in the Narrow gauge album (page 101). As Zach has said I wanted a simple loco to build that still looked realistic but without the need for internaly firing. So a design was devised after seeing videos of the older Bowman locos, being built around two single acting oscilating cylinders. To keep it simple reverse valves were omited but to give some control a simple but effective regulator has been fitted. The wheels are from an old mamod loco even thought they are over size for it to be a scale loco. The aim was never to build a scale modle but more to capture the character of the original. Apart from the wheels I have constructed all the parts myself. The drawings for the loco will be made avaliable in the future.
Tech specs:
Length 180mm, width 60mm, height 85mm
Boiler capacity is 45ml
Cylinder bore is 8mm, stroke is 18mm
Run time is around 25 minutes
Haulage is limited to 5 slate wagons
Below is the full set of photos taken during constuction and a video to prove it works.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/kDZJqeymEUU?fs ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/kDZJqeymEUU?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/WzWE4-nZNVY?fs ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WzWE4-nZNVY?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Tech specs:
Sir haydn
- 90733
DLRdan
Sir haydn
- andysleigh
Matt
yeah, I think I'd build mine to look like Bonnie Dundee did before it's 1996 rebuild.laalratty wrote:That looks very nice, although if I ever build one I reserve the right to turn it into a 1/12th scale 0-4-2 tank loco, and then decide to take off the added side tanks and turn it into a tender loco
- 90733
pauly
? Iv read the thread againa nd dont quite understand what you mean...90733 wrote:So do I, but talking to Mr. Bond the idea is that is the project goes ahead you wont need 'specialist' equipmentpauly wrote:Nice!
I wish I had the equipment to build a steamer liek that or a cracker :(
A steam propelled life-style.
- 90733
Don't understand me?pauly wrote:? Iv read the thread againa nd dont quite understand what you mean...90733 wrote:So do I, but talking to Mr. Bond the idea is that is the project goes ahead you wont need 'specialist' equipmentpauly wrote:Nice!
Thanks
Jack
Jack
bessytractor
