GVT stock in 1/16th scale
Durley
Post by Durley » Mon Dec 15, 2025 2:17 pm
I’ve been building some Glyn Valley Tramway stock in 1/16th scale (3/4” or 19mm to the foot), so I’ve started this thread to share some photos. At this scale, the GVT gauge of 2’ 4 1/2” equates to 45mm so matches my SM45 track work.
First up, here’s a few photos of the open 3rd carriage which I have modelled in early condition with fully open ends and the original GVT livery.
The model is a mix of 3D resin printed bodywork, milled aluminium angle axle guards/bearing holders, Slaters 7/8ths scale wheels, Trenarren Models couplings (too small at 16mm scale but look ok). The roof is made from milled Perspex rails with 3D printed ribs, basswood planking is sheeted with thin balsa sheet and covered in masking tape to simulate canvas. The details are mostly 3D printed parts.
The distinctive Greek fret lining was painted using washi tape masks cut on a Cricut machine. The GVT monogram was a special order from Endon Valley Custom Decals.
Re: GVT stock in 1/16th scale
Post by Peter Butler » Mon Dec 15, 2025 2:29 pm
Absolutely superb! The colour and lining are excellent and all detailing looks faultless (as far as I am aware).
I'm a little unsure about your choice of passengers... the man in black looks to be up to no good at all.
Durley
Post by Durley » Mon Dec 15, 2025 5:07 pm
Peter Butler wrote: Mon Dec 15, 2025 2:29 pm Absolutely superb! The colour and lining are excellent and all detailing looks faultless (as far as I am aware).
Thanks Peter. That’s Llyn ‘light fingers’ Ffransis. He can do you a good deal on a nice barely used gold pocket watch, as long as you pay cash and ask no questions 😉
Post by LNR » Mon Dec 15, 2025 11:08 pm
Wow!
Some very fine detail there, and of course the figures the icing on the cake. I've been wondering about a Cricut machine to finally get around to providing some data panels on my rolling stock.
Post by philipy » Tue Dec 16, 2025 8:03 am
Very nice John, especially the lining which really sets them off, as others have said.
LNR wrote: Mon Dec 15, 2025 11:08 pm I've been wondering about a Cricut machine to finally get around to providing some data panels on my rolling stock.
I got the basic Cricut m/c ( Cricut Joy) ages ago, just to try to do my own lining and lettering. It does have some limitations but I'm not sure if the more expensive versions would be any better. The problem I have is that if it has to do multiple cuts, i.e inside and outside of a rectangular shape, the registration goes a bit to pot. Trying to cut the vinyl lining for my F & B loco, the narrowest I could get it to do is 0.4mm because it tries to do some at 0 mm and some at 0.5mm, because the registration slips. To do 2 or more colours requires matching cuts and fiddling to get them together accurately, see the drop shadow on "No.2".
This is the said loco, so far, and I'm debating whether to put lining on the wheels ( The various components are not yet fixed together):
Post by ge_rik » Tue Dec 16, 2025 8:11 am
Excellent! The lining is the icing on the cake!
Durley
Post by Durley » Tue Dec 16, 2025 9:05 am
philipy wrote: Tue Dec 16, 2025 8:03 am
Thanks Philip, your loco lining is very impressive. I use my wife’s Cricut Maker 4. The best I could do was a 0.8mm wide lines. The washi tape I am using is low tack and very delicate so tends to pull from the backing and tear as it cuts with lines any thinner. Vinyl would be better but I agree, it’s not going to do better than you have achieved with the Joy.
Post by Peter Butler » Tue Dec 16, 2025 10:41 am
The lining on this locomotive was done with a vinyl cutter, although I have no idea which one...
Kay is so proficient she measured and cut all of them while I waited, drank coffee and talked models with her husband.
Durley
Post by Durley » Tue Dec 16, 2025 11:42 am
Peter Butler wrote: Tue Dec 16, 2025 10:41 am The lining on this locomotive was done with a vinyl cutter, although I have no idea which one...
The lining looks great Peter, very neat.
Durley
Post by Durley » Fri Jan 02, 2026 10:19 am
Some photos of my 1 ton slate wagons. Left over from the GVT’s horse haulage era, these diminutive wagons were used to carry finished slates for transshipment at Chirk. I have made 4, but need to add another 3 for a prototypical rake as they usually ran as 7 wagons in total, marshalled at the tail of a train, in front of the brake van. I assume 7 wagon loads would fill one standard gauge open wagon.
The models are mostly 3D resin printed. The floor planks are from basswood, with the distinctive lathe and bobbin style bodywork as a one piece 3D print on top. The couplings are brass castings for strength, attached via eyebolts that are soldered in a brass tube running along the centre line of the wagon and held in machined aluminium brackets. This transmits the drawbar loads through metal, rather than rely on the resin structure to take the load. The floor/solebars structure incorporates the brakegear, all 3D printed as one part. I usually prefer to mount the running gear in metal bearing holders but in this case, the lack of room led me to attach the brass bearings directly into the relatively bulky resin printed axle boxes. Wheels are Slaters 7/8ths scale which are the correct diameter but slightly too chunky to be scale, they do however add some decent weight to the wagons which helps them run well on the track.
The slate stack loads are resin 3D prints. I created a single slate as an STL file using the Meshy AI tool, that I then digitally copied multiple times and combined to create the stack, before printing.
Post by ge_rik » Fri Jan 02, 2026 2:26 pm
Beautiful, as ever, and the paint job is the final perfect touch.
Post by philipy » Fri Jan 02, 2026 3:26 pm
That is incredibly impressive with all that brake gear printed as part of the solebar and floor. I've been trying to visualise how you would orientate it to minimise the supports - my brain 'urts! :lol:
tommygander1941
Post by tommygander1941 » Fri Jan 09, 2026 1:51 am
Durley wrote: Fri Jan 02, 2026 10:19 am Some photos of my 1 ton slate wagons. Left over from the GVT’s horse haulage era, these diminutive wagons were used to carry finished slates for transshipment at Chirk. I have made 4, but need to add another 3 for a prototypical rake as they usually ran as 7 wagons in total, marshalled at the tail of a train, in front of the brake van. I assume 7 wagon loads would fill one standard gauge open wagon.IMG_5680.jpegIMG_5681.jpeg
Now THESE are really good! Would you be at all willing to share these, as I would love some 16mm SM32 versions :D
Durley
Post by Durley » Sat Jan 10, 2026 6:19 pm
tommygander1941 wrote: Fri Jan 09, 2026 1:51 am
Happy to share the files but I’ll have to do some measuring to see if they’ll work at 16mm SM32 Tommy. As I’ve modelled the wagons to scale, the back to back on SM32 wheelsets is too narrow at 16mm scale for the GVT’s 2’4.5” gauge and may therefore interfere with the underframe. The brakes will also not be aligned with the wheels…
Post by Old Man Aaron » Sun Jan 11, 2026 2:52 pm
Well up to your usual standard, Durley. Works of art.
Loading and trans-shipping individual slates must've been a miserable job. You must be thankful for resin!
ask4smithy
Post by ask4smithy » Mon Jan 12, 2026 5:35 pm
Bravo!
Superior craftsmanship. Your skill set in creating the files is impressive. :salute:
Makes want a Resin printer.
Steve A. :thumbup:
Durley
Post by Durley » Thu Jan 29, 2026 9:48 pm
A few workbench photos of my latest output. The 4 ton granite wagon carried the majority of the GVT’s freight tonnage. Made ubiquitous in 16mm garden railways due to the excellent Binnie injection moulded plastic kit, my version is mostly all resin and makes into quite a chunky wagon in 1/16th scale.
In the early period I am modelling, the prototypes were painted red oxide with iron work picked out in black. Painting wagon strapping in a different colour when in place on the model is one job I really dislike, so I chose to make all the strapping and bolts separately so the body could be sprayed red and the ironwork painted black before being attached. This approach also allowed painting of the interior to replicate bare and weathered wood, and some weathering of the body, before the ironwork was attached. Recesses in the body ensured the ironwork could be accurately positioned. Lettering is sprayed white using masks cut on the Cricut machine.
Wheels are Slater’s 7/8ths scale running in 3mm oilite bearings mounted in milled aluminium angle bearing holders, all hidden behind 3D printed axleboxes. Couplings are still to be mounted, I’ll use prototypical hook and shackle (castings from Model Earth).
I want to make a rake of these wagons, photos suggest most GVT mixed trains ran with at least 5 granite wagons and sometimes many more.
Jbs
Post by Jbs » Fri Jan 30, 2026 9:25 am
I agree with the above comments. What a superb wagon. The seperate iron work is a very good idea for painting. I would also like to print one of these, and I think the 1/16th scale could fit in well with some of my 7/8ths stock.
John
John Smith
Harrogate
Paul_in_Ricky
Post by Paul_in_Ricky » Fri Feb 13, 2026 9:10 am
That's a lovely model Dursley. Great lettering and internal finish too.
An interesting approach to print out strapping separately. It's worked very well for your scale, but might be less applicable to smaller scales.
Durley
Post by Durley » Wed Feb 18, 2026 7:03 am
Thanks for the comments gents. John, I’ll make the files for the granite wagon available on the 3D printing section of the forum shortly. I do want to make a few tweaks to some components before sharing as I needed to do a bit of fettling of some of the internal ironwork on this build due to designing some of the tolerances too tight.
