Baseboard Construction
Warwickshiresteam
(I think this is the right place for this topic, I can't see a section for baseboards; perhaps someone will re-direct me if it is better posted elsewhere)
I have a raised station area, 18ft by 2ft, constructed of 18mm ply (supported by three longitudinal beams) covered in roof felt. It has lasted 25 odd years but now needs replacing. Last time I used marine ply but that is now almost £200 for an 8 x 4ft sheet (and I need two), so the obvious question, what else could I use?
Standard ply is about £35 a sheet so if I cover it better than I did last time would that last OK? Or are there any other materials now available that could be used?
Re: Baseboard Construction
It's a thorny question and everybody has a different opinion!
I think you've done pretty well getting 25 years from ply but I can understand your reluctance to spend £200 a sheet to replace it.
Personally, I'd suggest using felt covered decking boards on a framework of treated timber and held up by square rainwater downpipes set in Postcrete.
Using plastic sheet materials tend to be affected by heat/cold and give buckling/warping problems.
Yes, I agree with Philip. These days it's hard to get good quality weatherproof ply - basically, you get what you pay for! I've used tanalised fence rails and they have lasted years (not quite as long as your ply). Some cheaper untreated timber I used to fill a couple of gaps have very quickly rotted away - a false economy. So fence rails or decking boards are definitely the way to go.
I agree with both replies, my gravel boards (decking boards by another name) which are pressure treated, 6"x1" softwood, have shown no signs of deterioration during the past eleven years. Supported off the ground and covered with roofing felt they are still firm foundation. A coat of preservative might give extra protection while still accessible.
- SimonWood
I disagree with Philip
So far three people have the same opinion. Actually, make that four, decking board is probably the way I'd do it too.philipy wrote: Thu Mar 21, 2024 2:00 pm It's a thorny question and everybody has a different opinion!
Warwickshiresteam
Thanks very much for the responses; one query, when the gravel boards dry out have you had problems with them slightly warping across the width so, say, 4 laid side by side creates a slightly wavy surface making it difficult to keep track flat?
And a PS: When I said the ply lasted 25 years, to be strictly accurate it has been in place 25 years - one bit was replaced 10 years ago and the rest has been laminating badly for almost as long, so I really only got about 15 good years!
As shown in my picture, I have more than four planks side by side and haven't had such an issue. However, I live in West Wales, which is notorious for being wet, so I doubt my boards were dry when installed! To avoid swelling it might be a good idea to add some moisture before fixing so they can only shrink.Warwickshiresteam wrote: Thu Mar 21, 2024 4:02 pm Thanks very much for the responses; one query, when the gravel boards dry out have you had problems with them slightly warping across the width so, say, 4 laid side by side creates a slightly wavy surface making it difficult to keep track flat?
- GAP
I use fibre cement sheeting, I have found that I have to use the external type as the type for use under eaves does not really stand up that well to being wet. Its OK while in place but handling it wet takes a lot of care.
I overcame that by painting it with a cheap exterior weatherproof paint.
I find it easy to cut using a diamond concrete blade in an angle grinder.
The type in the blog post pictures below is exterior which I also painted to get rid of the bright white colour.
https://ringbalin-light-railway.blogspo ... cross.html
- Lonsdaler
Fibre cement sheeting is available from the usual stockists in the UK, usually advertised as bathroom tiling backing sheet. I have 2 boards which have been stored outside ready for a project I have not yet got around to. They are completely unaffected by the elements so far (rain, frost and sunlight). Properly supported, these are the way I shall go.
