Can someone please tell me what is the typical weight (ready to run with water, gas, rc gear, etc) of 16mm loco.
I am interested in the larger ones i.e. 0-6-0 or 0-6-2 ?
For example
https://www.roundhouse-eng.com/fowler.htm
https://www.roundhouse-eng.com/russell.htm
etc...
loco weight?
- bambuko
- Jimmyb
Re: loco weight?
The link for the Fowler says the loco is 3.4 Kg, I assume dry weight, water capacity is around 300 ml, so 300 gms, so wet weight will be around 3.7kg.
- bambuko
Re: loco weight?
Thanks @Jimmyb, not only having senior moment, but also blind
Problem solved
Problem solved
