RAF Fauld wagon
andysleigh
RAF Fauld wagon
Post by andysleigh » Fri Apr 17, 2009 2:04 am
Over the last 12 hours or so i have been building an RAF Fauld wagon.
Based on the one now located at Amberley
http://amberleynarrowgauge.co.uk/fauldwagon.htm
The chassis is an old Binnie engineering skip chassis.
The wood i used is Hobby's 10mmx2mm pine strip. Great stuff, the only down side to the stuff is it has massive grain, so it wouldnt really make good scale wood for 16mm.
The straping is small brass angle, which i found on a cheap tool stool at the great dorset steam fair of all places! (was unable to find any small enough in model shops, or even a model engineering rally)
I would quite like to make another, but using naturally dark wood, with small grain, so it looks more like the original. Mine has paint slapped on all over it, which doesnt looks to good close up.
mhlr
Post by mhlr » Fri Apr 17, 2009 2:06 am
Very good Andy!! Got lots of charm! :D To get the darker wood, why not use a dark wood stain? Or old oil mixed with a bit of white spirit and paint that on - good mucky effect.
andysleigh
Post by andysleigh » Fri Apr 17, 2009 2:20 am
mhlr wrote:Very good Andy!! Got lots of charm! :D To get the darker wood, why not use a dark wood stain?
Because i dont have any dark enough :oops:
What i build normally relies on what i can find lying around
mhlr wrote:Or old oil mixed with a bit of white spirit and paint that on - good mucky effect.
Never heard of that technique before. May have to try it. I'v tried oil on its own, but that didnt do much...
SillyBilly
Post by SillyBilly » Fri Apr 17, 2009 9:37 pm
That's a lovely waggon, I quite fancy makeing a steel sided one now I've seen yours.
Hancockshire
Post by Hancockshire » Fri Apr 24, 2009 6:19 pm
WOW!!!!!!!!!!!!! great work. :D where did you get the sizes for it?
andysleigh
Post by andysleigh » Fri Apr 24, 2009 6:28 pm
Hancockshire wrote:WOW!!!!!!!!!!!!! great work. :D where did you get the sizes for it?
Thanks
I didnt get any sizes.
Its based on a binnie bolster chassis, which is a certain size.
I gessed the height and width until it looked right.
i am now half way through making another one for MTA (who isnt on here anymore)
Just waiting for the ruddy angle to arrive :x
