GRS 32mm gauge diesel and tippers
Kubes
Post by Kubes » Mon Feb 19, 2018 12:40 pm
I've seen an advert for what looks like a very affordable little battery powered rtr diesel from GRS priced at £299 including four tipper trucks. Does anyone have any more info on this?
Kubes
Kubes
Re: GRS 32mm gauge diesel and tippers
Post by tom_tom_go » Mon Feb 19, 2018 1:21 pm
I saw that advert in latest 16mm NGM and it looks tempting.
Post by Lonsdaler » Mon Feb 19, 2018 2:22 pm
I think it's a 'show only' special for Peterborough. :?
jimmytrains_01
Post by jimmytrains_01 » Tue Feb 20, 2018 4:45 pm
Matt has nearly sold the whole of the first batch. Sample is in their shop at risborough. defo not just the show model
Dasher
Post by Dasher » Tue Jul 10, 2018 10:56 pm
Has anyone had a go at modifying one of these yet? - Converting to RC, fitting a sound module or rechargeable battery for example. I'm going to do something with mine as it is just too slow (I like 'slow' but mine is very slow) - and for me shunting requires a radio.
I'd be grateful of any experience that can be handed down - there's not a lot of room inside the body.
Post by tom_tom_go » Wed Jul 11, 2018 8:17 am
If you search 'GRS motor' someone is doing a motor kit to make it faster although this model was only meant for shunting about the yard and not mainline running.
R/C wise, Deltang will fit well in the small space.
Check out www.rctrains.co.uk
Gralyn
Post by Gralyn » Wed Jul 11, 2018 11:03 am
Upgrade kits are available on Ebay at GBP49.00
Search 16mm Scale.
Dasher
Post by Dasher » Wed Jul 11, 2018 4:02 pm
Hi all - thanks for the responses.
I am aware of the upgraded motor / gearbox kit on eBay. It also comes with upgraded lights (tbh I'm not that worried about the lights). I'll speak with RCTrains about options for controlling the 12V motor and sound.
I understand that it isn't a 'main line' engine, and I'm not even sure that the upgraded motor/box is a great deal better than as supplied. RC is my first priority and, as whist I'm in there, my thinking was to add the upgraded motor /gearbox and a sound card. It is actually a nice little loco - just a bit pedestrian and, for me, requires control for shunting.
Post by tom_tom_go » Wed Jul 11, 2018 4:33 pm
I have seen one in the metal and it's a nice model but a bit small for my liking. You might be asking too much of it to fit R/C and sound in it with space for battery and speaker even if you use LiPo batteries.
The brass pole that pokes out of the cab for speed or direction control (can't remember what it does now) was a bit of an after thought...
Dasher
Post by Dasher » Sun Jul 15, 2018 11:55 am
having had a good look inside now I can see that things can be done. However, I've decided that the loco is probably best left as it is and use it for doing slow circuits with its own set of tipplers. The money that I would spend is best put towards an Accucraft Baguley or a Criccieth Castle (my preferred choice if I ever find on).
Post by tom_tom_go » Sun Jul 15, 2018 12:54 pm
I have a Baguley on order for that reason as it has loads of space to convert.
Palmerston
Post by Palmerston » Sun Jul 15, 2018 2:25 pm
The loco is a model of the LKM NS2f
Live steam on 45 & 184mm, battery 45mm only.
Dasher
Post by Dasher » Sun Jul 15, 2018 5:15 pm
...and actually a very close approximation at 16mm/ft. So, although he looks small, actually isn't. I notice that the exhaust stack on the real thing is much further forwards - but that's not an issue with mine as the thing fell off when I took it out of the box and it requires a pin putting in it to get it to stick back, which I haven't got around to yet.
Palmerston
Post by Palmerston » Fri Jul 27, 2018 12:16 pm
Dasher wrote: Sun Jul 15, 2018 5:15 pm ...and actually a very close approximation at 16mm/ft. So, although he looks small, actually isn't. I notice that the exhaust stack on the real thing is much further forwards - but that's not an issue with mine as the thing fell off when I took it out of the box and it requires a pin putting in it to get it to stick back, which I haven't got around to yet.
Over the years replacement engines have been fitted, hence relocating the exhausts.
Dasher
Post by Dasher » Sat Jul 28, 2018 10:45 pm
Ah! Thanks!!
Post by -steves- » Mon Nov 19, 2018 5:59 pm
An oldish thread I know, but for info.
I have just picked one of these up too.
I believe that there is sufficient room to put some 3 small 18350 batteries in it (12.6v fully charged) and an RX65c Deltang receiver. I have thought about a sound card, but need to see what space will be left, quite a bit I hope once I rip the other bits out of it.
As per another post on here, it appears the guy that runs RC Trains has RC'd a few of these and I am hoping to hear from him about the best way to do it.
