Another wagon from IP Engineering
steamer68
Post by steamer68 » Tue Dec 12, 2017 10:13 pm
Just ordered another wagon from IP Engineering its the hinged coal wagon from their Ezee range which I think are ideal for my MSS loco and its an interesting way of getting involved in kit building. Does any one have experience building the Ezee range any pointers will be helpful. :thumbleft:
Re: Another wagon from IP Engineering
Post by FWLR » Thu Dec 14, 2017 10:07 am
Just take your time and don’t rush it, plus read the instructions 1st, although they are pretty basic, they do change sometimes, but it is pretty much an easy build.
steamer68
Post by steamer68 » Thu Dec 14, 2017 2:38 pm
Thanks Rod I'm looking forward to another build and I will be taking my time no rush. :)
James from Devon
Post by James from Devon » Thu Dec 14, 2017 6:17 pm
I agree with Rod. IP stuff is usually excellent (I have had / still have lots of IP kits) but do have a good read through first and, most importantly, enjoy it. There is no better feeling than seeing something you made yourself out on your track. I have become more hooked on building stock than running my railway!
If you do make a mistake, don't hesitate to give Ivan at IP a call for any help. He's happy to offer advice on his kits.
It's nice to see someone new to the hobby starting with some kits rather than RTR... much respect to you!
J
steamer68
Post by steamer68 » Thu Dec 14, 2017 6:44 pm
Hi James many thanks for your advice and kind words. It will be nice to see my kit wagons going around my layout I'm looking forward to start kit building. This is something I can do while I am running in and enhancing my MSS loco and of course something to keep me occupied over the winter months. :thumbleft:
steamer68
Post by steamer68 » Sun Dec 17, 2017 3:14 pm
Received my Ezee range coal wagon from IP Engineering just a question as this is my first wood build kit do I cut along the out lined shape or do I leave a millimeter or so for light sanding and filing. :thumbleft:
Post by tom_tom_go » Sun Dec 17, 2017 3:34 pm
Can you post a pic of what you are trying to cut please?
steamer68
Post by steamer68 » Sun Dec 17, 2017 4:16 pm
tom_tom_go wrote: Sun Dec 17, 2017 3:34 pm Can you post a pic of what you are trying to cut please?
Hi Tom here is a picture of one the wood boards.
Post by tom_tom_go » Sun Dec 17, 2017 4:26 pm
You only need to cut the tabs that are holding the pieces to the wooden fret board. They will then pop out.
File the tabs afterwards if you do not get a clean cut.
steamer68
Post by steamer68 » Sun Dec 17, 2017 4:33 pm
Hi Tom thanks for pointing this out to me. :D
Post by FWLR » Thu Dec 21, 2017 5:27 am
Pretty easy really, most β€œcard” builds are the same, you need to remove any small burrs from them after cutting through with a very sharp knife.
steamer68
Post by steamer68 » Fri Dec 22, 2017 12:03 pm
FWLR wrote: Thu Dec 21, 2017 5:27 am Pretty easy really, most β€œcard” builds are the same, you need to remove any small burrs from them after cutting through with a very sharp knife.
Hi Rod thanks for your reply they do look straight forward to build. :thumbleft:
Post by FWLR » Sun Dec 24, 2017 6:51 am
One other thing Kevin, even though they are an easy build, take your time and try not to get any glue on the outside of the panels, they are a bit of a pain when you come to stain or paint them, it kind of darkens the area they have got on. I usually put the wood glue in a small container and use an old paint brush to put the glue on, that way you can control how much of it you put on the model.
Merry Christmas :santa: :santa: :santa: :santa: :reindeer: :reindeer: :reindeer: :reindeer:
JMORG
Post by JMORG » Sun Dec 24, 2017 10:34 pm
Hi Kevin,
Looks like you're cracking on! If you ever fancy anything different, contact Rob at Swift Sixteen:
https://www.swiftsixteen.co.uk/
The smaller kits don't really needed building, basically you stick your buffers and wheels on and that's it. The larger kits again at similar in difficulty, except you might need to stick sides on bogies.
The detailing is also exceptional. We've got several of his wagons and they really look the part! Also; if you fancy a battery loco, they perform arguably better than a Roundhouse battery at a fraction of the price and with much better finish.
Also, get some pics of your progress!
