Steve
Post
by Steve » Wed Jun 29, 2016 12:04 am
Just finished my first building in Coffee Stirrers.
and at just £8 for 2000 from Ebay - that's a lot of 4"x 1"x 10' planks
Cuts easily with scissors,
glues fast with a good weatherproof PVA - Everbuild 502
Laminates to make strong 4" x 2" or 4" x 3" or even 4" x 4" main Timbers.
Using 5mm foam Board as a base cladding gives a quick finish.
Post
by Big Jim » Wed Jun 29, 2016 12:16 am
Looks good. What did you use for the roof slates?
Post
by LNR » Wed Jun 29, 2016 12:19 am
That's a beautifully constructed building Steve, you've spent a fair bit of time spacing out all those boards so evenly. Would that be something you would leave outside?
tuppenced
Post
by tuppenced » Wed Jun 29, 2016 12:35 am
Nice!
What percentage of stirrers do you find useable please? - it's about a quarter for mine. David
Steve
Post
by Steve » Wed Jun 29, 2016 12:38 am
Jim
Would you believe that slate roof is a slate roof.
I use Wickes slate floor tiles - the better ones in packs of 5.
Cut into 20mm strips with a tiles saw
Cut into 30mm long chunks
I then have lots of tiles 1'3" x 1'10", on the larger size for roof tiles but just what the Lines Architect ordered.
Only problem the tiles are 7" (10mm) thick.
Leave in a bucket of water several days, then Split them with a thick bladed Long Kitchen Knife (not very sharp). Wear Gloves and make sure they are Cut Resistant 3 or 5 builders type.
Flat piece of hard wood (Old window sill) with a stopper
put the tile up to the stop- hold the knife on the tile with the grain and tap the back of the knife. The tiles will split. Then split again and again, until you have 5-7 pieces of tiles around 1" thick.
Keep practicing, you will get better
DON'T forget the CUT RESISTANT GLOVES
Steve
Post
by Steve » Wed Jun 29, 2016 12:40 am
Grant
Leave outside - No
although the roof is waterproof
The glue is waterproof
The wood has been sprayed with a Lacquer so hopefully waterproof.
Steve
Post
by Steve » Wed Jun 29, 2016 12:45 am
David
I use about 98% yes some are a bit bent and so is only usable as short parts.
Maybe some makes are better other?
tuppenced
Post
by tuppenced » Wed Jun 29, 2016 12:56 am
Wow! Thanks, Steve. Any tips for a good brand or supplier, please?
I've just laminated-up two 10" long beams, but my stirrers were so variable that I measured up three times as many stirrers as I needed, writing the widths and thicknesses on each one, then lined them up in size-order to choose two sets of near-enough ones. (Very laborious, but done for a good reason.)
Good to be cautious with water. Even if your structure has a waterproof lacquer 'skin', big changes in humidity will cause wood movement that will crack it and let water in.
Making test walls to leave outside will show what works and what doesn't.
When splitting roofing slates, the Welsh would halve and halve and halve again to get down to thickness. But sometimes in 16mm I've got away with taking repeated slices off one 'end', like slicing a loaf.
David
tuppenced
Post
by tuppenced » Wed Jun 29, 2016 1:17 am
I've ordered a box immediately! Thanks, Steve. David
Post
by ge_rik » Wed Jun 29, 2016 7:08 am
Very nicely done! The slate roof is a master-stroke. Reminds me, my stocks of stirrers is running short. I find them really useful for all sorts of things (including stirring paint etc.)
Post
by MDLR » Wed Jun 29, 2016 11:28 am
I take the view that bent / warped / otherwise unsuitable for construction sticks go for stirring paint and mixing epoxy resin glue.................
Steve
Post
by Steve » Wed Jun 29, 2016 12:42 pm
depends which way they are bent.
2 glued together in the opposite bend cancel each other out.
The bad bend often can be cut to make a small piece.
very few are unusable.
timber in the real world is often bent or even twisted.
Post
by philipy » Wed Jun 29, 2016 2:45 pm
Steve,
Very nice building, and thanks for all the construction tips.
Steve
Post
by Steve » Wed Jun 29, 2016 7:55 pm
Anyone else have building from Stirrers to show?
merlin2
Post
by merlin2 » Wed Jun 29, 2016 8:52 pm
Very impressive indeed; and as already said, thanks for the tips especially regarding the tile manufacture.
Merlin
Post
by jim@NAL » Wed Jun 29, 2016 9:38 pm
fantastic job looks very good and they are super straight coffee strainers
KjellAn
Post
by KjellAn » Wed Jun 29, 2016 9:58 pm
Steve:118742 wrote:Anyone else have building from Stirrers to show?
Here is my little station building on my PHRy (the Pine Hill Railway).
The station was built of 4mm ply glued together with PVA. The coffeestirrers was then glued to the ply like your building. As you can see it was outside in wet and cold weather, and this wasn't good for the ply after some time. The humid weather maked the ply splitt in some places, mostly on the base and lower parts of the walls.
I have now restored the station by some woodenscrews and PVA. And have made a new roof made of acrylate sheets and roof tiles from Plasticards (US).
Now I keep the building stored in my garage when not having a steamup.
KjellAn on Tue Jan 24, 2017 9:08 pm, edited 1 time in total.
Kjell Anderdal
Steve
Post
by Steve » Wed Jun 29, 2016 10:56 pm
Very nice Kjell
A great photo taken in a beautiful country. I am visiting again in August.
I like the boards at the end of the roof. I hope you don't mind me stealing that idea, stirrers already being cut up.
I will see if I can get a snow photo this coming winter.
Steve
SapperAnt
Post
by SapperAnt » Sat Jul 02, 2016 1:25 pm
Cracking job!! I feel the muse fluttering around me....
Users browsing this forum: No registered users and 51 guests
