Beck Anna
Alan P
Beck Anna
Post by Alan P » Sat Apr 18, 2015 9:35 am
Hi Guys,
I recently added a lovely Beck Anna to my loco fleet and thought it would look nice with a brass dome. After a bit of reasearch on the net i opted for one from Garden Railway Specialists,
http://www.grsuk.com/Dome_Brass_Fairlie-M2777
It was a bit of a gamble but as luck would have it, it fitted perfectly. As Merlin Maestros have the same boiler it would do as replacement for their domes. It would also most likely fit some of the other Merlins, the Matterhorn and Matador come to mind.
Anyway, just thought this might be useful info. Below is a pic of my Anna, i've also added some boiler bands. The sharp eyed among you will probably notice that she appears to be a hybrid of a black and a green Anna.
Dannypenguin
Post by Dannypenguin » Sat Apr 18, 2015 9:46 am
Nice little engine you have yourself there :thumbright:
Dan
Alan P
Post by Alan P » Sat Apr 18, 2015 9:51 am
Thanks Dan. I was very lucky with this one. Bought it from a very nice guy called Charlie O'Mahoney who is one of the drivers down at The Launceston Steam Railway. It appears to have had very little use and runs like a swiss watch :)
Post by tom_tom_go » Sat Apr 18, 2015 11:24 am
Like it, the brass dome works well on this one and does not make it look toy like.
Can we see it running please?
Post by Big Jim » Sat Apr 18, 2015 11:53 am
Very pleasing to the eye.
Its nice to see an early engine still in almost 'ex-works' condition.
Alan P
Post by Alan P » Sat Apr 18, 2015 12:49 pm
There is a short clip of her running here,
https://www.youtube.com/watch?v=GP-INzs ... e=youtu.be
This was taken before the boiler bands & dome were added. Apologies for the dodgy camera work, i'm afraid my videos aren't in the same league as Mr Birds!
Keith S
Post by Keith S » Sat Apr 18, 2015 6:56 pm
Looks very nice with the dome. There are several features I like about that locomotive, including the gas tank being in the bunker instead of in the cab... well they needed to do something in order to make room for that monumental pressure gauge!
funandtrains
Post by funandtrains » Sat Apr 18, 2015 9:41 pm
Looks like you have a Merlin Beck Anne there rather than a true Beck.
kandnwlr
Post by kandnwlr » Sun Apr 19, 2015 9:26 am
Alan P:110268 wrote:There is a short clip of her running here,
Now, that´s an excellent video on an attractive little line. Your new loco already looks at home.
Alan P
Post by Alan P » Sun Apr 19, 2015 3:49 pm
I did wonder if it was an early Merlin but it does have a Beck plate in the cab,
Post by Big Jim » Sun Apr 19, 2015 7:55 pm
Not wishing to dip my fly in your ointment but my Maestro has a Beck tag on it.
Alan P
Post by Alan P » Sun Apr 19, 2015 8:27 pm
Hi Jim, not at all, i'm learning all the time here so any information is useful :)
That's interesting, i have two Maestros and neither have the Beck plate. Although the later one does have the small metal bracket that the plate is usually riveted to.
Post by Big Jim » Sun Apr 19, 2015 8:55 pm
Mine has been hacked about a bit, I think in order for Mr Cooper to fit RC, The bottom corner has been cut and bent back in order for the rod to fit.
I may be wrong but weren't the early Merlins built from Beck bits left over from when Beck finished. Or even Beck built engines sold as Merlins?
It is still a nice looking loco and the gas knob on the tank is much better than poking out of the cab front.
Alan P
Post by Alan P » Sun Apr 19, 2015 11:04 pm
Mine that has the bracket is the same.
According to the esteemed Marc Horovitz, Beck went bust in 1981 and Tom Cooper bought up the remaining stock. He used some of this to produce some of the early Merlin locomotives, specifically the Maestro, Midas, Monarch and Matador.
ianpearse
Post by ianpearse » Mon Apr 20, 2015 8:41 pm
Hi Alan
That is a very interesting Anna you have there! It is the chassis that interests me the most.
It looks as if you are running on 32 mm gauge; please correct me if i'm wrong. The original Merlin Beck Anna locos (Tom Cooper era) were re-gauged to 32 mm by having the old chassis completely modified and the side chassis members moved inwards. The chassis were all made from brass angle. Your chassis is completely flat on the top of the footplate.
It looks like your chassis is one of the cast chassis's developed by Alec Mathesson. He and Tom went to the Beck factory when it went bust. Tom bought some of the stock of remaining parts and Alec bought the rest of the parts and tooling. He set up a company in Telford to supply further parts when Tom Coopers supply ran out. Alec was a very good engineer and developed the new cast chassis which was much superior to the old brass chassis. It had a cut out at the back to fit an AA battery box for powering the R/C when fitted. If you can let us see an underside image of the chassis this will confirm this. Unfortunately the partnership between Tom and Alec did not last! Alec sold all his parts and interests to Roundhouse who re-introduced a few Anna's with their slide valve cylinders. However you will have to ask Roundhouse about these developments.
Also the cylinders on your model puzzle me. The original Beck ones were not drilled right through and fitted with end caps, also both the piston rods and piston valves were nickel plated brass, yours look plain brass. That's no worry, just use plenty of good steam oil.
Regards the boiler plates - all the old Beck boilers had them fitted, a leftover from the stock bought from Germany. Some were removed when R/C was fitted, others were left on.
So it is difficult to say what era your model came from. But I can definitely say that up till 1986 no cast chassis were used at Merlin Loco works.
I hope this bit of insight into the history of Merlin and its developments help. All in all I think you have a very pretty loco that should give you pleasure for many years to come. Oh and I know all this as I worked at Merlin from 1982 to 1986!
Alan P
Post by Alan P » Mon Apr 20, 2015 10:53 pm
Hi Ian,
Thank you so much for sharing that information. It's all very interesting, i had no idea about the chassis developed by Alec Mathesson or indeed his involvement with Tom Cooper.
Yes i run 32mm. I think you might be correct on all accounts, i've taken a couple of close-up shots of the underside and they certainly bear out what you have been saying.
The chassis definitely looks like a machined casting to me.
Close-up of the cylinders,
Thanks again,
funandtrains
Post by funandtrains » Tue Apr 21, 2015 5:59 pm
You certainly have an unusual loco the cylinders look a little like those on the Steamlines Little Giant (Aileen) but not exactly:
http://www.alspcs.com/Aileen1.JPG
Users browsing this forum: BryanW and 139 guests
