Edrig Bodykits
SpudUk
Edrig Bodykits
Post by SpudUk » Sun Jan 11, 2015 12:17 am
Hey Folks,
So I am finally taking my first tentative steps into 16mm and by the end of the month will have an Edrig. I'm looking into body kits and wondered if anyone could recommend body kits available on the market, with pictures for a rough idea of size?
Thanks
JMORG
Post by JMORG » Sun Jan 11, 2015 9:56 am
Swift Sixteen do an excellent kit called Owain. Its a chunky body with tanks inspired by the Vale of Rheidol locomotives. It also features their unique adjustable opening spectacles as well!
Robs very friendly and will give you help whenever you need it! 😃
Llanwellyn
Edrig Body Kit
Post by Llanwellyn » Sun Jan 11, 2015 12:17 pm
Hi,
Have a look at my Mikes Models Baldrig conversion.
It's a 16mm kit not 7/8th scale
Go to my Youtube uploads to see the assembled kit running before it was painted. LLANWELLYN is my user name. Scroll down my uploads to find it. In fact there are two uploads of the same kit. Easy to put together and great quality.
John.
SpudUk
Re: Edrig Body Kit
Post by SpudUk » Sun Jan 11, 2015 2:14 pm
Llanwellyn:107349 wrote:Hi,
John.
Ah, I've seen your loco. How tall is it from track to cab roof, looks massive?!
Chris Auckland
Llanwellyn
Baldrig
Post by Llanwellyn » Sun Jan 11, 2015 2:27 pm
It's 155mm. Thats to the middle top of the back of the cab roof.You should remember that Edrig is a G scale loco not 16mil. Its big when stood next to say a Lady Anne. Are you modelling in G or 16mm? I do both on 32mm track. Best of both worlds. If I were to start out fresh I would have 45mil track. I went the 32mil way so I could run Finescale locos, Peckett and Quary locos and have stuck with it.
John.
SpudUk
Re: Baldrig
Post by SpudUk » Sun Jan 11, 2015 2:47 pm
Llanwellyn:107353 wrote:It's 155mm. Thats to the middle top of the back of the cab roof.You should remember that Edrig is a G scale loco not 16mil. Its big when stood next to say a Lady Anne. Are you modelling in G or 16mm? I do both on 32mm track. Best of both worlds.  If I were to start out fresh I would have 45mil track. I went the 32mil way so I could run Finescale locos, Peckett and Quary locos and have stuck with it.
John.
I'm using 32mm but will be modelling roughly 2' 6" so want stockier locomotives. Also hoping to to have majority W&LLR-type stock from Accucraft
Chris Auckland
Llanwellyn
Post by Llanwellyn » Sun Jan 11, 2015 2:52 pm
This should match up well. Best of luck.[/b]
Post by MDLR » Sun Jan 11, 2015 3:13 pm
I've got a Baldrig XT - see www.mdlr.co.uk/loco20.html. Bear in mind that it is rather bigger than most other locos - I actually "found" some infrastructure on Matt Acton's line with the cab roof, and I have now got my W&LLR van out of store, so that the roof line on a train does not seem to vary as much - look at the photos and you'll see what I mean!
SpudUk
Post by SpudUk » Sun Jan 11, 2015 4:00 pm
MDLR:107356 wrote:I've got a Baldrig XT - see www.mdlr.co.uk/loco20.html. Bear in mind that it is rather bigger than most other locos - I actually "found" some infrastructure on Matt Acton's line with the cab roof, and I have now got my W&LLR van out of store, so that the roof line on a train does not seem to vary as much - look at the photos and you'll see what I mean!
You don't happen to have a picture of it alongside your W&LLR van do you? Worried it might be slightly too stocky
Chris Auckland
Post by MDLR » Sun Jan 11, 2015 4:12 pm
Not yet - van only got finished during this week and I won't be playing trains until Wednesday at the earliest! (But I will take pictures then.........)
SpudUk
Post by SpudUk » Mon Feb 02, 2015 11:40 am
So, finally picked up my Edrig yesterday, and I am now officially a 16mm locomotive owner (yey).
Brian, don't suppose you've managed to get a shot of your WLLR van and Rincewind side-by-side yet have you?
Chris Auckland
Post by MDLR » Mon Feb 02, 2015 12:56 pm
SpudUk:107893 wrote:Brian, don't suppose you've managed to get a shot of your WLLR van and Rincewind side-by-side yet have you?
(FX)
(Grumble, mutter.......)
(Grabs camera - sound of steps going downstairs)
(Gets loco and stock)
(Discovers normal 1 yard length of track is not long enough)
(Mutter, CURSE, Grumble)
(Goes to shed to get lengths of Mamod track)
CLICK!! CLICK!!
(sound of steps coming UP stairs)
Going bunker first, the difference isn't so apparent, but it'll now run chimney first and looks rather better with the van.
SpudUk
Post by SpudUk » Mon Feb 02, 2015 1:14 pm
You're a kind man, thank you :D
Chris Auckland
Joe
Post by Joe » Mon Feb 02, 2015 3:54 pm
very nice, will that fit a ragleth too?
SpudUk
Post by SpudUk » Mon Feb 23, 2015 12:15 pm
That's not an Accucraft W&L wagon is it Brian? Looks shorter then I'd expect it to
Chris Auckland
Post by MDLR » Mon Feb 23, 2015 5:25 pm
SpudUk:108483 wrote:That's not an Accucraft W&L wagon is it Brian? Looks shorter then I'd expect it to
No - it's a Brandbright kit which I built in 1989 (and it has the Works plate to prove it.............)
