I have run 2 Pintail engines with a vertical boiler on Butane/Propane mixed gas which have had no burner problems, although a fellow member advises me he gets it occasionally on his Pintail powered steam lorry.
Whilst I've never suffered it with my Cheddar Iver, both fired on butane only & butane/propane mixed gas, a fellow owner got in touch for some advice recently including a howling burner.
I have suffered it on my Cheddar/GRS tram and originally I noticed that the gas jet had been pushed well into the mixer tube, and it was fitted with an air control ring. However it was running too rich and putting the jet to the correct position increased the howling.
Chris Bird has written on-line that he has reduced his howling burner by turning the gas control valve down, but on my Cheddar/GRS tram with the gas set at the lowest setting to hold the required pressure whilst running (approx. 20-30PSI) the burner still howls.
By accident I found that placing a piece of kitchen paper towel over the top of the chimney stopped the howling completely. So it was finding a suitable piece of mesh to replace the paper towel.
I have some stainless steel 40 mesh which did stop the howling when placed on top of the chimney. However it is too fine to allow the lit gas to pop back to the burner on light up. As I use a piece of silicon tubing supplied by Cheddar Models to collect the condensate when first running these locos I made a hole in the mesh (just over 7mm diameter) which allowed the silicon tubing to be fitted onto the exhaust pipe during warm up, and the hole is big enough to allow the lit gas to pop back to the burner OK.
In use I've found that there is less of a wet exhaust steam now than previously (the flue below the mesh is obviously hotter now) and you only get a noticeable steam plume at the end of a run when the gas has run out (running indoors). I'm keeping the gas control valve at the lowest setting possible just to maintain the required pressure. However there is now no more howling from the burner.
I suspect that a less fine mesh would probably work just as well but I do not have any available to experiment with.
Although Jerry at Clevedon Steam (a former Cheddar Models employee) sells a replacement gauze fluetube burner apparently his selling point "When used on Cheddar locos, the familiar howling noise is eliminated " does not apply to the Cheddar Iver.
(spelling)
