Been looking at new Accucraft loco's (at the moment to dream about
Where are the loco's built?
Are they reliable?
Whats the running like?
Tanks in advance!
Accucraft valves are stainless steel running in honed bores. They should not wear as long as proper steam oil is used because they are running in oil, not metal to metal. I have had many locomotives and use mostly Roundhouse and Accucraft. Both have their good points but Roundhouse D valves will last a very long time – as will Accucraft piston valves. I have to say that you would probably work through several sets of running gear before either type of valve will show any sort of wear at all. Indeed even my old Merlin Mayflower is still running happily today after 25 years use here and four years use elsewhere. Accucraft valves are much better than these.LnBmad:94396 wrote:Having not owned an accucraft loco I can only comment from my research.
D-slide valves wear in and get better with use, hence running in. Piston valves are at their best when just made, after that they start to wear and piston valves wear out. This shouldn't be off putting but should be a consideration for future maintainance.
The accucraft locos I have seen have run beautifully and I would love to own a Lew!
