Adding the Dirt Factor - Vans
TTHLRMatt
Post by TTHLRMatt » Tue Aug 20, 2013 6:48 pm
Recently I have had various pieces of stock, mostly vans, which I simply cant run in my trains as they look too "ex works". I have already weathered one brandbright van heavily but today I took a few hours to "walk all over" :lol: an andel small van!! The photos in my mind dont quite do it justice how mucky it is.
Upon seeing the footsteps I had a great idea to paint in foot prints on the roof as if someone walked on it to check the couplings ect.
As I said, sitting by it now, the photos dont do it justice but still, very good!!
Post by bazzer42 » Tue Aug 20, 2013 7:29 pm
That looks good Matt, what's the recipe?
TTHLRMatt
Post by TTHLRMatt » Tue Aug 20, 2013 8:13 pm
To start it was given a wipe down (this was done a month after painting) to clear any muck from running. The maroon bits were heavily brushed with revel 46 and 87. Only do two panels at a time as as soon as the paint is on, you get a rag and smudge it around the panel, dulling it and putting muck in the gaps between the planks. The footprints on the rood were added with 46 and the muck on the steps too.
Make sure when rubbing the paint around to get it into the lower horizontal strapping and corners as the muck would collect in real life.
Add some railmatch dark rust to some open parts of the strapping in light but concentrated stokes, also on the hinges, latch and corners.
Over do these with a mix of 46 and 87 (or close, I used some 67 and 45 as well, all matt) dry brushed, licking the brush around the corners. This dulls the colour.
On the roof add some 75 around the edges, heavy on and then rubbed off to make the edges look like water has been collecting on them, like streak marks almost.
My no 1 rule is no BLACK. Black is not a natural colour, it is often grey and so everything was done over to chalk it up for word for a phrase. I have different techniques for different scenarios. This wagon is the sort that gets used but sits outside most of the time in an open situation but is also showing signs of age.
I will be continuing this thread for other vans, and another thread for more, like my crane wagon.
Thanks for the nice complements.
:lol:
*Warning* Do not use a good brush, you are going to mistreat it a lot and so, dont buy the most expensive!!
Post by bazzer42 » Tue Aug 20, 2013 8:41 pm
Simple or so you make it sound!
Keith S
Post by Keith S » Tue Aug 20, 2013 10:01 pm
Very nice and grubby: Some of my wagons need this treatment.
Sylvian Tennant
Post by Sylvian Tennant » Tue Aug 20, 2013 10:17 pm
Some nice work there young man :D
TTHLRMatt
Post by TTHLRMatt » Tue Aug 20, 2013 10:32 pm
Thank you, it is easy if you have tried before, I have a rubbish wagon which is now, rubbish after various experiments :)
My other van is far better!!!
Post by MDLR » Wed Aug 21, 2013 3:42 pm
Nice to see the rust on the "iron" framing - as somebody  who once owned a 305mm:foot example, I can ASSURE you that that those corner plates can rust very badly!!
TTHLRMatt
Post by TTHLRMatt » Wed Aug 21, 2013 7:04 pm
Yes indeed, when weathering, you need to think in a realm of logic where dirt would collect and so on and where would be adverse to rust
METHSSNIFFER
Post by METHSSNIFFER » Wed Aug 21, 2013 8:47 pm
I like to see the odd rivet missing the flaking paint the streaks of rust running from dark to light and a washed weathered look on the roof even a bit of pidgeon dung doesnt go a mess sorry a miss.
TTHLRMatt
Post by TTHLRMatt » Wed Aug 21, 2013 9:13 pm
Yeh this one is very light weathering, hence the dull, the rust, the footsteps, other wagons and so on like a wood kit especially is getting the blowtorch :twisted:
