Pop Type Safety Valve
Hope Mountain Railway
Hello All, I wonder if anyone can help me please? I want to make a safety valve similar to the old Roundhouse 'Pop' or 'Rasberry' type. I believe the diameters of counterbores and dimensions within are critical for the correct working of quick pressure release, and immediate closing. Archangel use them extensively, I believe. Thanks
GardenSteamer
I've experimented with pop type safety valves and there seem to be three main factors in getting them to work reliably with the minimum of hysteresis at the required operating pressure.
They are the ball diameter to steam hole ratio, the depth of the shoulder and the rate of the spring. The last is the trickiest to get right.
I'll try and post a drawing of the designs I have made. I must confess that I still struggle to make one so that it operates well. Good luck and be prepared to experiment.
Pop type Safety Valve
Hello Garden Steamer,
Thanks for that. I look forward to seeing the drawing.
What has instigated this is a R/House Vor which wastes an awful amount of steam from about 10 psi onwards until blows off properly at 40psi.
Best Wishes,
Gareth
Best Wishes,
Gareth
GardenSteamer
- Chris Cairns
