Merlin gas tank
pauly
Merlin gas tank
Post by pauly » Sat Aug 11, 2012 5:59 am
Having received and fitted a new filler valve to my merlin its became clear that the tank itself is now compromised, the valve itself is no longer leaking but theres still a leak.
I dont know how to fix this, gas tank repair is not within my knowledge.
Where would I even be able to get a replacment gas tank???
Im at a complete loss as to what to do here guys.
A steam propelled life-style.
pauly
Post by pauly » Sat Aug 11, 2012 7:50 am
The fille valve doesnt seem to be going in or sitting at the right angle, looks like the thread has been pushed into the tank a little bit, all those years of gas filling hvae taken their toll it seems.
Im not sure how to get the tank out, since it resides in the roof I thought it would be a simple process of taking the roof off and just lifting it out but the rook appears to be formed with the rest of the body shell so it looks like Id pretty much have to take the entire loco apart to get to it which Im hesitant to do.
DLRdan
Post by DLRdan » Sat Aug 11, 2012 11:31 am
If it is anything like the Merlin Meteor I repaired there is one nut throught the cab rook which holds the gas tank in. you will have to take the gas line out to get the tank out.
pauly
Post by pauly » Sat Aug 11, 2012 12:01 pm
perhaps the Meteor had a bigger cab because it all looks so snug and hemmed in, I cant see a way of taking it out with taking magority of the cab apart.
I want to be sure of what Im doing before I mess with this loco
Vapouriser
Merlin gas tank
Post by Vapouriser » Sat Aug 11, 2012 3:58 pm
Strange as it may seem. You could try Roundhouse !
pauly
Post by pauly » Sat Aug 11, 2012 7:15 pm
would they really help?
pauly
Post by pauly » Sat Aug 11, 2012 11:26 pm
a standard gas tank or a custom to fit my merlin?
Busted Bricks
Post by Busted Bricks » Sat Aug 11, 2012 11:32 pm
What are the dimensions? Tanks are easy to make and I have a tap to cut the right thread for the filler valve. Post a picture if you can.
pauly
Post by pauly » Sun Aug 12, 2012 2:49 am
Ill phone RH this monday
Cant really get at th etank to take dimensions but Ill post a pic of it tomorrow
pauly
Post by pauly » Tue Aug 14, 2012 12:18 pm
I tried RH but they told me they wont touch my Merlin but they did give me a number for a chap named Barry who has apparently worked on a lot of Merlins
taliesin
Post by taliesin » Wed Aug 15, 2012 8:07 pm
What type of Merlin is it? cheers Rob
Post by laalratty » Wed Aug 15, 2012 8:43 pm
pauly:73804 wrote:I tried RH but they told me they wont touch my Merlin but they did give me a number for a chap named Barry who has apparently worked on a lot of Merlins
That'll be Barry Milner, in which case your loco would be in safe hands, although I believe his services can be on the pricey side
pauly
Post by pauly » Sat Aug 25, 2012 12:15 pm
he wouldnt touch it
Iv goen to Finescale who say they can give me a replacement tank but wont fit it to the loco, Ill have to do that myself.
Now can someone please for the love of all that is good tell me how to take a Merlin Mayflower apart so I can get its gas tank out.
I have no desire to take this loco apart and then find myself stuck with a load of useless bits because I can get her back together properly.
Everyone says to just undoe this one screw in the roof to get at the gas tank well Iv tried that and all it does is give the tank some free movement, I cant actually remove it from the cab.
taliesin
Post by taliesin » Sat Aug 25, 2012 1:22 pm
Four screws under the running boards, two each side. Undo the gas pipe at the jet body, should be able to lift body clear but be careful not to catch any wires. Gas tank attached by one nut on roof, cheers Rob
pauly
Post by pauly » Sat Aug 25, 2012 2:43 pm
Thanks Iv got it off now
taliesin
Post by taliesin » Sat Aug 25, 2012 2:56 pm
Great, when you come to reassemble it do not do the four screws that hold the body on very tight, the lump of brass attached to the body have a habit of breaking off, hard, but not impossible to reattach without damage to paint work, cheers Rob
pauly
Post by pauly » Sat Aug 25, 2012 4:18 pm
yeah I know... one of them broke off when I was taking the body off.
a spot of glue should do fine for now
