ptlrcecil wrote:A mamod boiler should do the job as long as it can get enough heat in it and produce enough steam eg a 5 wick meths burner under an sl1 boiler but then garret 100 is the real expert in these matters.
Still laughing here... a real expert....
Loved that one...
Do you know how you find out about boilers...? Failures, that's how!
Having a boiler that you're sure will be fine for the job & then finding that it'l hardly get warm...
Seriously though - a mamod boiler is designed as a toy to be made & sold within the rules & regulations that the likes of Mamod have to abide by. The downside is that although used in the application it's designed for, it's great (the mamod loco must hold the world speed record, possibly eclipsing Mallard...), but it won't do a lot else.
Being a 'pot' type boiler, you just won't get the output from it that you need to do much more than power a couple of Mamod cylinders.
Although the Salem Garratt (not the Locobox version) is also a pot boiler, it's a lot larger & has a lot more powerfull burner.
You have to start thinking big! Or at least bigger...
Chris (Garratt100) (That's Garratt, spelt garratt...)
