planty
Post
by planty » Wed Nov 09, 2011 8:18 pm
I recently had a number of parts fitted to upgrade my MSS engine.
- Dead-leg Displacement Lubricator
Steam Regulator Kit
Upgrade Cylinders
After two or three times firing up the cylinders are still a bit "sticky", they run for a while and then stop, a quick nudge and they'll run again, stop etc (for a while I'm talking 5-20 seconds or so)
Has anyone else had experience of such upgrades? Do they take a while to free up/run in?[/list]
anythingsdr
Post
by anythingsdr » Wed Nov 09, 2011 8:27 pm
They take a while to bed in, I think its normal... My Mamod didn't like it when i put a new upgraded cylinder in with an older bedded in one!
DolwyddelanLightRail
Post
by DolwyddelanLightRail » Wed Nov 09, 2011 8:46 pm
It takes a bit of time to run them in, strangely I found it takes longer for new cylinders on a mamod to run in than a new Lady Anne, it was either that or I just wasn't thrashing it enough
DLRdan
Post
by DLRdan » Wed Nov 09, 2011 9:11 pm
Welcome to the forum. The cylinders will take a while to run in but there are a couple of things to check. If the gland nuts on the back of the cylinders are too tight they will be clamping the piston rod, causing lots of drag. The other thing is to make sure the lubricator is definatly working as the upgrade cylinders do like oil. The only other thing is to be patient and keep running it.
dougrail
Post
by dougrail » Wed Nov 09, 2011 9:25 pm
What Dan said. Also be careful not to abuse the cylinders, they might pop off!
Post
by DolwyddelanLightRail » Wed Nov 09, 2011 9:46 pm
dougrail:60870 wrote:What Dan said. Also be careful not to abuse the cylinders, they might pop off! :shock:
I've never had a problem with that, and Britomart has hauled my edrig once or twice now! and that isn't a light load!
dougrail
Post
by dougrail » Wed Nov 09, 2011 10:13 pm
Well I had to get a cylinder repaired, Dol.
However, far from being a negative, Dream Steam took receipt of the cylinder, and repaired [replaced?]the piston and housing unit within a week
even after it had been bought for a year - but with proof of purchase and mindful of the fact it was one of the last of the Plymouth operation produced, much credit to DS!
Post
by DolwyddelanLightRail » Wed Nov 09, 2011 10:47 pm
Reading back on what i said there, it did look rather braggy, didn't mean to sound like that, sorry! But regarding dream steam, they're customer service is brilliant! Can't fault it really!
And also regarding hauling power etc, I've had to cut down on how much I put behind her, as dragging the edrig is what caused the wheel to slip on the axle, and also since cutting down on the loads, it hasn't been breaking as much!
dougrail
Post
by dougrail » Wed Nov 09, 2011 10:49 pm
Naw, you're alright Dol, didn't come across as braggy. Just explained where I was coming from.
Now, as for loads and wheels, am I right in thinking y'm stil on Mamod originals?
Post
by DolwyddelanLightRail » Wed Nov 09, 2011 11:07 pm
dougrail:60877 wrote:Now, as for loads and wheels, am I right in thinking
Normally I'm good at guessing what people try to say when they make typo's but i'm stumped by this!
It probably doesn't help that I'm on the last HST out of London to York, and i'm rather tired
Post
by Narrow Minded » Wed Nov 09, 2011 11:13 pm
DolwyddelanLightRail:60879 wrote:dougrail:60877 wrote:Now, as for loads and wheels, am I right in thinking
He said "Is your loco still fitted with Mamod / MSS original wheels, as opposed to higher quality replacement wheelsets?"
Post
by DolwyddelanLightRail » Wed Nov 09, 2011 11:19 pm
Narrow Minded:60880 wrote:DolwyddelanLightRail:60879 wrote:dougrail:60877 wrote:Now, as for loads and wheels, am I right in thinking
He said "Is your loco still fitted with Mamod / MSS original wheels, as opposed to higher quality replacement wheelsets?" ;)
Post
by Narrow Minded » Wed Nov 09, 2011 11:21 pm
DolwyddelanLightRail:60881 wrote:Narrow Minded:60880 wrote:DolwyddelanLightRail:60879 wrote:dougrail:60877 wrote:Now, as for loads and wheels, am I right in thinking
My turn now then - "are they Dream Steam Steel wheels? and if so I take it one of them
still came loose?"
planty
Post
by planty » Wed Nov 09, 2011 11:32 pm
Thanks for the comments all.
I'll keep firing it up over winter so hopefully come spring will run like a dream on the track!
Post
by DolwyddelanLightRail » Wed Nov 09, 2011 11:36 pm
Narrow Minded:60882 wrote:
My turn now then - "are they Dream Steam Steel wheels? and if so I take it one of them still came loose?"
Nope, twas the originals that slipped!
(Notice the different in height between the two wheels on the conrod)
I've never had a problem so far with the steel wheels, and yes they are from Dream Steam, but I got them second hand, but were never used
dougrail
Post
by dougrail » Wed Nov 09, 2011 11:53 pm
My God, He's Finally Sorted Out His Wheels! :lol:
Trust me mate, you won't regret the switch to steel!
Much more power can be used, I reckon you could haul the Edrig again
Much smoother running too. Steel wheels should be compulsory.
...y'm still be needing steel rods me hearty, arrrr :twisted:
But it looks like you took a blowtorch to Britomart?
Post
by DolwyddelanLightRail » Thu Nov 10, 2011 12:01 am
dougrail:60885 wrote:My God, He's Finally Sorted Out His Wheels! :lol:
But it looks like you took a blowtorch to Britomart? :shock:
I couldn't be bothered sorting the old ones out, and a set of steel wheels for £10 new was something I couldn't miss out on! and well, I'm not keen on giving it heavy loads otherwise the PTFE tape thats stuffed in the steam pipe to stop it leaking around the T pipe to the lubricator gets pushed out the way and leaks like bu99ery! and it a pain to try to resolve!
and the blowtorch was to get the old paint off, i then got the rest of it off with a paintstripper, then on with the new paint, which looks a lot like BR blue!
Post
by -steves- » Thu Nov 10, 2011 7:25 am
planty:60863 wrote:I recently had a number of parts fitted to upgrade my MSS engine.
Steam Regulator Kit
Upgrade Cylinders
The upgraded cylinders also have upgraded springs. These springs tend to be a bit too much and no amount of "running in" will fix that. What some people do is change the springs back to the original cyliner ones, and personally, I just get the new ones, put them in a pair of big pliers and clamp them back up (do not do that if you do not have spare springs to hand). Either way, please please please try it and watch your Mamod gain a new lease of life. I have had to do this with 3 sets of upgraded cylinders now and it works everytime
Best of luck :D
planty
Post
by planty » Sat Nov 12, 2011 10:24 pm
Best of luck :D
Presume the springs are fairly easy to get out? I didn't do the replacement job myself so can't say I've ever dismantled the cylinders.
Also what do you mean clamp them back up? Compress the spring to stop it expanding so much?
Cheers for the info tho, much appreciated!
