Lamps and Detailing
dougrail
Lamps and Detailing
Post by dougrail » Fri Aug 05, 2011 5:43 pm
I recently acquired a trio of lamps and some GRS frets off Ebay. I thought they were ornamental only and two of them were - white, roundhandle, one red, one white lens.
The third is a sleek black number with a working amber LED! And the whole set only cost me £12. :shock:
Now here's the problem.
I'd like to use a fret to hang a lamp off the smokebox of a Mamod-smoke-fitted locomotive. I initially thought epoxy might work, but the smokeboxes get hot and so the epoxy would likely run [very likely run!]
What do people suggest?
ALSO
I'd like to try and rivet-detail the same smokebox as there is no way in Hell noone would sell me an original IPE Jane smokebox seperately from their loco [and I must say I can't blame them!]
Is there any advice, suggestions or how-to to go about this without cutting said smokebox up?
Many thanks gents
Re: Lamps and Detailing
Post by MDLR » Fri Aug 05, 2011 7:07 pm
dougrail:57213 wrote:I'd like to use a fret to hang a lamp off the smokebox of a Mamod-smoke-fitted locomotive. I initially thought epoxy might work, but the smokeboxes get hot and so the epoxy would likely run [very likely run!]
I'd gently drill and tap the smokebox to take a suitably-sized BA bolt and attach the lamp iron thussly. The Roundhouse ones come with two holes.......... Do the GRS ones?
dougrail
Post by dougrail » Fri Aug 05, 2011 7:15 pm
They do have two holes...two extremely small holes. I also have no screws as such so small. :/
Sir Clothem Cap
Post by Sir Clothem Cap » Fri Aug 05, 2011 8:12 pm
Drill a very small hole and superglue a bent and cut down dressmaking pin to make a mounting.
For extra rivet heads cut some dressmaking pins heads off and superglue in position then add black paint to seal them in place.
dougrail
Post by dougrail » Sat Aug 06, 2011 12:18 pm
Thanks fior the advice SCC. I had considered superglue, but I also know that the Mamod/MSS smokeboxes get red hot in use - wouldn't this melt the glue?
Sir Clothem Cap
Post by Sir Clothem Cap » Sat Aug 06, 2011 6:52 pm
I don't think so I have used it to attatch thr black pump bit on my mamod on the smoke box casting without a poblem
dougrail
Post by dougrail » Sat Aug 06, 2011 7:37 pm
What superglue is it that you used then? :)
'Black pump thing'? A vaccuum hose perchance?
Sir Clothem Cap
Post by Sir Clothem Cap » Sat Aug 06, 2011 8:48 pm
Image the bit on the smokebox casting.
dougrail
Post by dougrail » Sat Aug 06, 2011 9:23 pm
Cheers for the photo. :)
That's a sandbox I think?
Sir Clothem Cap
Post by Sir Clothem Cap » Mon Aug 08, 2011 10:47 am
The sand box was put on by a previous owner to "narrow gauge" it more. it is riveted on but had become wobbly so a drop of superglue has fixed it.
