George
Post
by George » Thu Jul 21, 2011 5:21 pm
Right, Thought my ragleth has a blocked gas jet (may still have) so i tried unblocking it in the usual way.
tried lighting it once back together however still nothing apart from a silent dull blue flame which sort of sits in the smokebox :|
any ideas?
its a lovely loco so im quite annoyed about this :(
Endless, Nameless
Post
by Endless, Nameless » Thu Jul 21, 2011 7:25 pm
Does sound like a blocked jet- or it's drawing in air from somewhere, try dropping a few drops of water on the unions. Is the jet back in the holder securely (with a wrap of PTFE) and is the holder sat straight in the burner?
Mr ACME
Post
by Mr ACME » Thu Jul 21, 2011 7:31 pm
George:56606 wrote:Right, Thought my ragleth has a blocked gas jet (may still have) so i tried unblocking it in the usual way.
any ideas?
Have you read the instructions on jet cleaning which come with the engine?
Have you resealed the thread on the gas jet with PTFE tape, which screws into the jet holder?
Sir haydn
Post
by Sir haydn » Thu Jul 21, 2011 7:36 pm
Also how did you clean the jet out?
I'v winced when some people have told me their way of doing it. The worst I heard was a chap who ran a small drill bit through it
Paul H
Post
by Paul H » Thu Jul 21, 2011 7:38 pm
Is the jet holder sealed into the burner sleeve? A friend had an air leak between the jet holder and the outer burner sleeve in the cab and had a similar situation. A wrap of rolled PTFE between the jet housing and the burner housing cured the problem.
George
Post
by George » Thu Jul 21, 2011 8:02 pm
dont worry guys i didnt do any horrific ways of cleaning it :lol: air leak sounds the likely cause looks like some PTFE is needed :)
Endless, Nameless
Post
by Endless, Nameless » Thu Jul 21, 2011 8:04 pm
Paul H:56616 wrote:Is the jet holder sealed into the burner sleeve? A friend had an air leak between the jet holder and the outer burner sleeve in the cab and had a similar situation. A wrap of rolled PTFE between the jet housing and the burner housing cured the problem.
That shouldn't need to be that tight, in my experience- but it does need to be straight! The important joint is the one mentioned by Mike.
Mr ACME
Post
by Mr ACME » Thu Jul 21, 2011 10:37 pm
He did what? AAARRRRGGGHHH!
bessytractor
Post
by bessytractor » Fri Jul 22, 2011 12:10 am
my Ruby did this on a visit to my mates on Tuesday. The jet was out of line with the rest of it. Gave it a tweak to try and straighten it out and it sorted it.
George
Post
by George » Fri Jul 22, 2011 12:24 pm
fixed it and it now works again, thanks for your helps guys
Endless, Nameless
Post
by Endless, Nameless » Fri Jul 22, 2011 2:36 pm
What was it George?
George
Post
by George » Fri Jul 22, 2011 4:39 pm
James-Buzz
Post
by James-Buzz » Fri Jul 22, 2011 7:54 pm
ferrysteam
Post
by ferrysteam » Fri Aug 26, 2011 10:37 pm
Good evening,
If I may give a tip on blocked gas jets,try opening the gas valve on the engine and filling it in the usual way.The extra pressure from the gas bottle usually clears the blockage,it saves a lot of messing about.But do it outside...A picy of me Leader....
George
Post
by George » Fri Sep 23, 2011 12:46 pm
as some of you know a few months ago the cross head came off the piston rod on ragleth, that was fixed however the same yesterday happened again when screwed back in the crosshead seems loose on the piston rod and comes off easily :/
any ideas?
Sir haydn
Post
by Sir haydn » Fri Sep 23, 2011 1:55 pm
check your still in warranty and get it fixed
