A NEW LOCO FOR THE MDLR (eventually)
Endless, Nameless
Matt assures me it has been run, but not much. I may get it back (temporarily) tonight so we can see where the R/C is going to go......... No whistle, unfortunately - no room!Endless, Nameless:56438 wrote:I was wondering that- it looks new!
Standard Baldrig XT or is it going to be something even more unique?
The same evening, the Berry Hill Works delivered a Working Steam Plant...........
..................with all the missing bits replaced. We're going to add the R/C once the body's built........
.................. because we suspect there'll be more room for batteries in the new body. The cab's only been plonked on the footplate in this shot - it's designed to be "clamped" between the buffer beam and the frames.
No pictures today (maybe tomorrow) but at least progress has been made! I got the loco back with the Stuart drain cocks fitted - they work fine (after a little tweaking of an over-tight one).
After this, I took my life in my hands and went for a run. It ran beautifully (though I couldn't get the gas down low enough - something to do with the cold weather) but trundled around light engine at a very gentle pace
I am no longer an Accucraft virgin!
- Keith S
The jury's still out on that - I've never had a pressure gauge visible from outside the cab, so I'll see how it goes.Keith S:64985 wrote:That's going to be very nice. I hope you turn the pressure gauge around.
In my case, the advantage is that it's going to look different - what it's made of is immaterial to me!Is the body made of nickel-silver? What is the advantage of this over the more conventional brass sheet?
............ and something a little different!In any case, it certainly will be a nice locomotive.
After a VERY long break (look when the previous posting was made) the body has made considerable progress, thanks to Jon Mead who had the kit to use in his soldering demonstration at Peterborough this year. Afterwards, he said "Would you like me to finish it?".............. Guess what I said!
The full story is on www.mdlr.co.uk/loco20.html but here's a taster...............
kandnwlr
MDLR:101393 wrote:After a VERY long break (look when the previous posting was made) the body has made considerable progress, thanks to Jon Mead who had the kit to use in his soldering demonstration at Peterborough this year. Afterwards, he said "Would you like me to finish it?".............. Guess what I said!
Now that´s going to be nice, I´m sure. Any thoughts about the paint job yet?
- Chris Cairns
- Dr. Bond of the DVLR
- Retired Director
