Plasticard?
- dougrail
Plasticard?
Hi chaps
I am just wondering whether if Plasticard, if wrought 'right' is a suitable material for SM32 rolling stock? I'm talking generic coaches here, nothing super-detailed or prototypical here. I ask because a set has come up for sale online and I have made first bid/intentions on it but am wondering what to do if Plasticard is not good enough?
Cheers
Cheers
peterbunce
Hi,
The thicker grades are OK, but do paint it inside and out to stop UV light getting at it, that makes it brittle.
I use it all the time. and re coaches the .060, and .040 are most used - Squires Tools do large (as post allows) sheets.
Better still is if you can get to an exhibition where they are is Eileens Emporium who have larger sheets.
MuzTrem
I've almost completed an SM45 bogie coach in plasticard (just got to finish the roof - a clerestory, because I'm a sucker for punishment!). I've found it to be OK as a material as long as you reinforce the joints with wood. I think wood would be better really but I find it a difficult material to work with with the limited tools at my disposal; plasticard is much easier.
Here's a picture of the vehicle so far - you can clearly see the wooden strips reinforcing the joints at the back corners.
- dougrail
Thanks chaps - having made first bids on a whole set [4 x 4wheelers, 1 4-wheel Guards and 1 x bogie] in Ebay I'm hoping I can win. Then once I get them home I plan to repaint them - either at least into choc and cream or retain the plum livery and paint round the windows for an LNWR look.
I will remember to consider 'reinforcement' as stated here provided I can prise the roofs off.
The reason I've gone for the set on Ebay is that I understand plasticard is a lighter weight - which means my Mamod-in-rebuild and my Ruston might have a better chance of pulling a decent looking train!
