Repainting the Bertie
mhlr
Post by mhlr » Mon May 03, 2010 11:48 pm
Decided my Bertie's paintwork was getting tatty, so I gave it a repaint... Turned out OK, not brilliant though. (notice a slight tone change 1/4 way down saddle tank, flippin' Humbrol pots not exactly the same and only noticed it after I took the pics!). I also removed those silly Micky Mouse handrails, hence the pop rivet in the hole the stantion was bolted to.
Pendo Pilot
Post by Pendo Pilot » Mon May 03, 2010 11:58 pm
Looks nice fella, can't really see the shade difference from the pics. You need to tart up the red on the buffer beams though.. ;)
It looks like a nice loco, may have to get one.
andysleigh
Post by andysleigh » Tue May 04, 2010 12:08 am
nice one pete.
turned out ok, will you be lining it one day?
mhlr
Post by mhlr » Tue May 04, 2010 12:27 am
andysleigh wrote:will you be lining it one day?
Did spend a while thinking about it, but I like this one as it is.
taliesin001
Post by taliesin001 » Tue May 04, 2010 3:50 pm
Looks great, and the colour difference isn't obvious at all.
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Tue May 04, 2010 8:09 pm
Coor Pete, your a dab hand with a brush (or did you air brush it?)
mhlr
Post by mhlr » Tue May 04, 2010 10:19 pm
Mr. Bond of the DVLR wrote:Coor Pete, your a dab hand with a brush (or did you air brush it?)
A fine brush, last time I tried my airbrush, it didn't work too well. Will have to practice on something less valuable at some point.
Post by 90733 » Wed May 05, 2010 6:47 am
Very nice, and if you don't mind me asking where did you get that 16mm logo 'headboard' hung on lamp iron?
Post by Narrow Minded » Wed May 05, 2010 11:45 am
It looks like an association membership badge to me :D
mhlr
Post by mhlr » Wed May 05, 2010 11:37 pm
Narrow Minded wrote:It looks like an association membership badge to me :D
Tis indeed, I broke the pin on the back, so just turned it into that instead! And 1:1 scale ones exist too!
Hancockshire
Post by Hancockshire » Sun May 09, 2010 9:17 pm
I never knew humbrol was heat proof. I tried on my TE1V & it didn't go well
mhlr
Post by mhlr » Sun May 09, 2010 9:37 pm
Hancockshire wrote:I never knew humbrol was heat proof. I tried on my TE1V & it didn't go well
It isn't. But I only used it on the body work... If you use it on the boiler, that gets over 100 deg. C, so it's not really going to work...
