Choppers
- Dr. Bond of the DVLR
- Retired Director
Choppers
I am considering converting to chopper couplings as they are more prototypicle, having carriages pulled by a 3 link chain is quite rare (although your all bound to correct me) so I bought two pairs of chopper couplings from Brandbright. I have heared mised reviews but what do you think about them? Also if I do get on well with them would anyone consider swapping a load of ip centre 3 link couplings for accucraft choppers?
Thanks
Thanks
Re: Choppers
He he, can't resist, Welshpool and Llanfair Railway uses a similar system, and also the War Department wagons use 3 link chains, although often with a very short middle linkMr. Bond of the DVLR wrote: having carriages pulled by a 3 link chain is quite rare (although your all bound to correct me)
Personally I wouldn't go with choppers, as everyone seems to use 3 link and whenever i've tried it (such as my ebay L&B wagons) i've had problems, with occasional uncouplings for no apparant reason etc. With Accucraft ones it is also a very good idea to remove the springs, overwise they don't have enough throw over on track of 3 foot radius or less (making things tricky on Peco set-track!)
- Retired Director
DLRdan
- Retired Director
Endless, Nameless
- Retired Director
grumpfuttock
Personally, I love chopper couplings. I started with 3 link buffer couplings way back in the 80's, but tried choppers and have never looked back.. Most of my stock has been converted to choppers (Accucraft and Tenmille). I have 7 Bachmann and 2 LGB G scale bogie coaches which are fitted with them (and sprung), and I have never had any problems, admittedly, my tightest curves are 4 ft radius. The height of the coupler needs to be pretty accurate to prevent uncoupling, and I must admit to the very occasional uncoupling for no apparent reason, mostly with Accucraft couplings.
I like shunting wagons etc. and found 3 link couplings to be a bit of fiddle. Also I encountered buffer locking when reversing on curves.
I remove the chopper from one end of each vehicle. They are easier to uncouple with just one chopper, especially vehicles fitted with Accucraft choppers couplings !
I use square and round, it doesn't seem to make a difference.
Endless, Nameless
- Retired Director
Hancockshire
Endless, Nameless
- Retired Director
Endless, Nameless
- Retired Director
