advice on carriages
Dr. Bond of the DVLR
advice on carriages
Post by Dr. Bond of the DVLR » Sun Oct 04, 2009 7:37 pm
Ok, in an attempt to make my passenger stock updated, varied, less shabby and more GER I decided to convert one of my 4 IP 4 wheelers into a 4 wheel balcony end carriage in teak. The conversion of the panel work worked well and is easy to 'edit' with a sharp knife. However the paint was a problem. In trying to remove the awfully tough paintwork the remaing panel work started to wear down allarmingly quickly and the sides are allready dangerously thin!
So to rectify the situation I have a huge bin of coffee stirirs 1000 approx that I bought from costa for a pound! What do we think of a match board coach that has tumble home sides and balonys?
I can then teak them up and make it a proper job!
Post by laalratty » Sun Oct 04, 2009 8:23 pm
Even though the side panels are thin, I would of thought that it would be quite hard to sand right throught them. I look forward to seeing what you achieve with the coffee stirrers :)
Post by Dr. Bond of the DVLR » Sun Oct 04, 2009 8:29 pm
So you think it sould look ok- I have never seen a tumblehome match side but then it could have been a design specific to the DVLR I suppose!
I am LASER cutting the ornate baclony ends as useuall!
DLRdan
Post by DLRdan » Sun Oct 04, 2009 8:32 pm
Hmm balcony ends, I wonder whose coahes you would be copying ;) Looking forward to the results
SillyBilly
Post by SillyBilly » Sun Oct 04, 2009 8:35 pm
Aslong as you stop sanding when the paint finishes and turns to wood shouldn't you be ok?
Post by Dr. Bond of the DVLR » Sun Oct 04, 2009 8:35 pm
well you know I am in love with your carriaged dan! The balcony ends are like the Wisbeech ones so I am keeping the design local!!!
Post by Dr. Bond of the DVLR » Tue Dec 29, 2009 10:35 pm
Right ho
progress finally!
Only one side done and still the balconies to do but what do youthink?
Hav I ruined one of my carriages or made something unique and teak (well it will be)
mhlr
Post by mhlr » Tue Dec 29, 2009 10:44 pm
Hmm look nice, a lot different from what the old IP coaches used to be :lol:
Post by Dr. Bond of the DVLR » Tue Dec 29, 2009 10:46 pm
Thanks, yeah it is alot different, I probs will not convert any more!
Post by laalratty » Tue Dec 29, 2009 10:48 pm
I think it looks alright, now you just need to scratchbuild some more to match :)
Post by Dr. Bond of the DVLR » Tue Dec 29, 2009 10:50 pm
and finish this one!
I am starting to collect rather a motly rake of cariages,
theres the normal 2 compartment IPs
this balcony end
a penryhn open,
two bug boxes!
I think it could look rather nicely mish mash
I will add LASER cut balcony ends as well with DVLR writen in them somewhere!
