IP Engineering Wickham trolley
Post by Phil.P » Wed Feb 28, 2024 5:01 pm
Does anyone have one of these?
If so, could you post photo(s) of the underside, and give me an idea of the space available for batteries etc.
Many thanks,
Re: IP Engineering Wickham trolley
Post by philipy » Wed Feb 28, 2024 5:05 pm
Can't help with the IP one ( I didn't actually realise they did one) but there are pictures of my 3d printed one on the thread I did at the time.
https://gardenrails.org/forum/viewtopic ... am+trolley
Post by Phil.P » Wed Feb 28, 2024 5:30 pm
Thanks for that..
I have had a query about fitting RC, and the customer is talking about swapping the motor, and using a PP3 battery..
I am wondering if a 3-cell AAA holder will fit, in place of the 2-cell?
Post by -steves- » Wed Feb 28, 2024 5:34 pm
Phil.P wrote: Wed Feb 28, 2024 5:30 pm Thanks for that..
You could use 2 x 14500 li-ion batteries, I know it's only 7.2v (8.4v charged) but it would be the same dimensions as the standard 2 x AA's, you could even use the same battery holder.
Post by Phil.P » Wed Feb 28, 2024 5:52 pm
I won't be fitting it, and I don't condone Lithium cells in holders. - Properly tagged/welded packs please.
I am guessing the customer already has NiMH batteries, and charger.
I always try to suggest a solution that works with what the customer already knows and loves..
Case in point:
I have a LGB loco (converted to batteries) with manual speed control. The 'charger' that came with it, is a 30V 3.15A laptop power supply!
I am hoping it is a case of the wrong item was put in the box with the loco, but I am drifting my own thread, here..
