Looks like this started life as a Mamod Lumber Wagon as there is evidence of rivets having been fitted to the chassis sideplates. Buffers, bufferplates and couplings removed and replaced with centre couplings and 3 link chains. Upper wooden bodywork with dummy coal load added to represent a loaded coal wagon.
The next three came from the same source, and share a common theme. The red buffer plates were removed, the buffers had their stock removed and used backwards to mount the oversized wooden buffer plate with wooden buffers. The coupling mount has been removed and replaced with a simple wire hook and 3 link chain.
This was a Mamod Open Wagon which has been repainted and kit bashed as above.
This is a basic Mamod chassis which has been kit bashed as above, and wooden bodywork added to make a boxed Goods Wagon.
This is also a basic Mamod chassis which has been kit bashed as above, and wooden bodywork added to make a nice Guards Van, together with an oversized lamp and a Guard figure.
Thanks for looking.
(edited to correct image links)
