Due to a non paying buyer, I have decided to use the whitemetal parts from an I P engineering kit and make a similar model
It will be 16mm scale running on 45mm track.
So first attempt at a scratch build and would appreciate some advice on what diameter axles ?
I have turned up the four wheels and now need to bore them, hence the question.
Thank you
dick
Axle diameter for a 16mm tram loco on 45mm track.
Dick
- -steves-
Re: Axle diameter for a 16mm tram loco on 45mm track.
Depending on the size, generally 3mm or 1/8th, if you have either size axle the choice is yours
Some including me go for 4mm or 5/32 on loco's so thats another option.
- -steves-
i fixed the typos now, lol
Dick
Many thanks for prompt reply
I have 3mm and 4mm silver steel in stock so will go with 4.
dick
dick
- -steves-
Good choiceDick wrote: Sat Nov 28, 2020 11:32 am Many thanks for prompt reply
dick
