Grub screws
Grub screws
Post by Andrew » Sun Nov 22, 2020 9:38 pm
Hello!
As I mentioned in my Railway thread, today's run with my Regner Konrad was cut short when the flywheel worked loose - the grub screw that holds it in place had gone missing.
It should be an easy fix, but I don't know how to identify what I need to buy to replace it. Can anybody advise on what size/thread etc I need please?
Thank you!
Re: Grub screws
Post by GTB » Mon Nov 23, 2020 10:34 am
Andrew wrote: Sun Nov 22, 2020 9:38 pm As I mentioned in my Railway thread, today's run with my Regner Konrad was cut short when the flywheel worked loose - the grub screw that holds it in place had gone missing.
That sort of thing is always a pain.......
First thing to check. Has the grub screw gone missing, or has it just loosened off and is still in the bottom of the hole. You may be lucky and just need to tighten it again.
Being a Regner model, it will be metric, likely an M3. The grub screw in the flywheel is likely to be the same as the ones used to adjust the wheels, which is M3 x 3 in the Regner Lumber Jack model. See if one of the screws from a driving wheel fits the flywheel. If so, then thats what you need to find.
A M3 x 3 hex socket grub screw is a common size, so should be easy to find a supplier. M3 is the thread size, so a M3 x 3 screw is a M3 screw that is 3mm long. It will need a 1.5mm hex key if it is an M3 grub screw.
If you aren't confident about measuring threads, it would probably be quicker to talk to Graham at Garden Railways Limited, who is the UK agent and get a couple of spares sent out, or as a last resort send an email to Regner.
Re: Grub screws
Post by Andrew » Mon Nov 23, 2020 10:48 am
Good advice, thank you!
I'll start with the wheels as you suggest (I'd forgotten about the grub screws on those), then contact Graham - I think it was him I bought the loco from c15 years ago, when his company was possibly called something else.
While I'm testing I'll see if they fit my Russell's Slomo, one of which has also gone AWOL - looks like I need to include grub screw tightening in my maintenance schedule...
Re: Grub screws
Post by -steves- » Mon Nov 23, 2020 11:19 am
If it turns out to need an M3 x 3 or similar, I have hundreds of them, more than willing to post you a couple FOC.
Steve
Re: Grub screws
Post by Andrew » Mon Nov 23, 2020 11:40 am
That's very kind, thanks Steve - I probably won't be able to check until next weekend now, but will PM you either way...
Re: Grub screws
Post by Chris Cairns » Mon Nov 23, 2020 7:15 pm
It is an M3 x 3 grub screw you require.
I endorse the recommendation to use Garden Railways Limited. I've had excellent service from Graham & Janet in supplying parts to keep my Regner loco roster running.
Re: Grub screws
Post by Andrew » Tue Nov 24, 2020 8:48 pm
Brilliant, thanks for confirming Chris!
Steve, looks like I'll be taking you up on your kind offer, thank you!
Re: Grub screws
Post by -steves- » Tue Nov 24, 2020 8:52 pm
No worries.
Just PM me your address and as soon as I can I will get some in the post to you.
Cheers
Steve
Re: Grub screws
Post by Andrew » Sat Nov 28, 2020 1:30 pm
Grub screws received today, many thanks Steve!
Re: Grub screws
Post by -steves- » Sat Nov 28, 2020 1:33 pm
Andrew wrote: Sat Nov 28, 2020 1:30 pm Grub screws received today, many thanks Steve!
Great, glad they got there so quickly :thumbup: A couple of spares never hurts to keep about :D
