Accucraft Yeo
- JMORG
Accucraft Yeo
So apparently I have a Yeo arriving next week... Is there anything different to the normal Accucraft practice with this engine? Has anyone who owns one had any interesting quirks with running them?
CSL
Re: Accucraft Yeo
"Apparently"? Is that the sound of extreme good luck?
- JMORG
Re: Accucraft Yeo
Prize draw, I didn't stay for the draw. Came back from the gym with a missed call telling me that I had won.
Are they identical to Lew?
Re: Accucraft Yeo
Congratulations,
The only thing I ever seem to win in drawers or raffles are non alcoholic beverages or ladies toiletries.
- TonyW
Re: Accucraft Yeo
No ... Lew's cab has a flat back, Yeo and the others have a curvy back to accommodate the internal coal bunker.
- JMORG
Re: Accucraft Yeo
Sorry Tony I meant mechanically.
I presume they're the same apart from bodywork?
- JMORG
Re: Accucraft Yeo
To be honest I wasn't even expecting anything. Never won anything and likely never will again...Big Jim wrote: Wed Apr 10, 2019 8:22 am Congratulations,
Re: Accucraft Yeo
Not to be a bad loser (I didn't enter anyway) but aren't you or your Dad in the trade so you are not allowed to enter?
- JMORG
Re: Accucraft Yeo
My father does make engines, but definitely not as a trader. He's an aerospace engineer by trade and simply makes engines for fun! He doesn't do draws or anything like that.
My sole locomotive is the Moel Tryfan so that doesn't count!
- JMORG
Re: Accucraft Yeo
Turns out one of our members bought himself a Taw. Runs very well although cylinders have leaky valve chests; is this a common occurrence?
copea
- New User
Re: Accucraft Yeo
I have a Yeo. A few points.... It does not hold a huge quantity of water so that needs some vigilance. When I fitted radio control the reversing lever was going ever so slowly past the “ stop” in forward which affected the performance until I discovered the problem. It had a tendency to slip which I solved by adding metal to the dummy side tanks to increase weight. Two problems, probably more to do with my track than the loco, the cowcatcher can easily come into contact with the rail and I stiffened the springing in the rear pony touch as I was getting occasional derails in reverse. I lost a pin out of the valve gear for no apparent reason. Despite the instructions saying it will run out of water before gas I have found it a little heavy on gas and this not to be the case.
Despite the above it’s a great loco now I have ironed out its foibles. It pulls well and looks good. Well done on winning it.
- JMORG
Re: Accucraft Yeo
Thanks copea! One of our members has had a Lew for a good few years now and it's a great runner; almost the equal to a Roundhouse (same with his NG15). Unfortunately, my reservations are born from our shared experiences with the NGG16's (both now sorted and running as well as they look) and his current troubles with the K1. I thought I'd ask the question first so I can have some sort of idea if things go wrong!copea wrote: Sat Apr 13, 2019 9:39 pm I have a Yeo. A few points.... It does not hold a huge quantity of water so that needs some vigilance. When I fitted radio control the reversing lever was going ever so slowly past the “ stop” in forward which affected the performance until I discovered the problem. It had a tendency to slip which I solved by adding metal to the dummy side tanks to increase weight. Two problems, probably more to do with my track than the loco, the cowcatcher can easily come into contact with the rail and I stiffened the springing in the rear pony touch as I was getting occasional derails in reverse. I lost a pin out of the valve gear for no apparent reason. Despite the instructions saying it will run out of water before gas I have found it a little heavy on gas and this not to be the case.
copea
- New User
Re: Accucraft Yeo
I do like the loco. If of interest there is a video of my Yeo here https://youtu.be/1oFbkTI0DFc
Re: Accucraft Yeo
Nice video of your line there.
I think the timing on the loco is out though?
copea
- New User
Re: Accucraft Yeo
Thanks for your comment. I am relatively new to live steam so am particularly interested in what you say about timing. My understanding with Accucraft is that there is a timing mark on the valve rod. Maybe I need to check this?
- dewintondave
- JMORG
Re: Accucraft Yeo
Yeo was dropped off yesterday and runs well! It was late in the evening (after gym) so no pictures yet sorry.
Users browsing this forum: No registered users and 56 guests
