Peco SM32 track
GWR
Peco SM32 track
Post by GWR » Sat Dec 29, 2018 8:30 pm
I'm just getting ideas and collecting information for when I start my garden layout. I'm planning on building an oval track using Peco SM32 track. What I would like to know is should i use 30 or 38 radius curve.
Ron
Re: Peco SM32 track
Post by -steves- » Sat Dec 29, 2018 10:19 pm
General rule is as big as you can fit into the space you have.
GWR
Re: Peco SM32 track
Post by GWR » Sat Dec 29, 2018 10:24 pm
-steves- wrote: Sat Dec 29, 2018 10:19 pm General rule is as big as you can fit into the space you have.
Steves thanks for your reply.
Ron
Re: Peco SM32 track
Post by Andrew » Fri Jan 04, 2019 3:07 pm
Hi Ron,
Apart from being a larger radius, 38" curves also have the advantage of matching Peco's points, which should make life easier...
GWR
Re: Peco SM32 track
Post by GWR » Fri Jan 04, 2019 7:05 pm
Andrew wrote: Fri Jan 04, 2019 3:07 pm Hi Ron,
Hi Andrew thanks for the reply. :thumbleft:
