O gauge track alternative
Clockwork
Post by Clockwork » Fri Oct 12, 2018 3:07 pm
Is there an alternative track I can use in O gauge to run my clockwork locos and wagons outdoors I know the flanges on clockwork locos can be an issue. Any advice would be welcomed. :thumbright:
Re: O gauge track alternative
Post by tom_tom_go » Fri Oct 12, 2018 5:26 pm
Code 200 rail should be alright but would avoid code 143 as I doubt the wheels will be able to go through points and sleeper chairs.
Clockwork
Post by Clockwork » Fri Oct 12, 2018 6:20 pm
tom_tom_go wrote: Fri Oct 12, 2018 5:26 pm Code 200 rail should be alright but would avoid code 143 as I doubt the wheels will be able to go through points and sleeper chairs.
Hi tom_tom_go thanks for your reply this is most helpful. :thumbright:
Post by Soar Valley Light » Fri Oct 12, 2018 7:35 pm
Kevin,
One of the pitfalls is the back to back dimension between the flanges of a wheelset. Tinplate stuff (Meccano in particular) is very coarse and the risk is that they may not fit between the check rails at a crossing nose and may ride up, allowing them to run into derailment.
I'm no expert on this, others may offer better advice and the internet will very likely offer further information. Good luck - it's nice to see Hornby trains being enjoyed outdoors.
Clockwork
Post by Clockwork » Sat Oct 13, 2018 8:23 pm
Hi Andrew thanks for your nice comments I am looking forward to running my clockwork trains on an outdoor layout.
f.schulz
Post by f.schulz » Sat Oct 13, 2018 11:12 pm
Hallo Andrew,
I run a Bing tin plate 0 gauge Life Steamer on MSS track with turnouts and have no problems with derailing until now.
Best wishes
Frederic
