Wheels galore
Busted Bricks
Wheels galore
We've been making wheels at work the last couple of days. The coolant pump relay blew earlier in the week and the tech guy didn't have a spare with him so there were a few days downtime on the machine. Those things only happen when you are really, really busy. Anyway, last few hundred will be run tomorrow and then I guess I will have the "pleasure" of manually deburring the rear of the bore.
11thHour
Re: Wheels galore
Wow, thatβs a lot of wheels!
Tim
Tim
Re: Wheels galore
Would you be doing them on a surface grinder. When I worked in the toolroom has an apprentice, one of my jobs was to make the blanks of the dies that the skilled guys were working on perfectly flat. So I would lay about ten, depending on the size of the blank and because the magnet was that strong it would hold them in place while I ran the grinding wheel across them. Granted it is all computerised now, but I loved doing it.
Busted Bricks
Re: Wheels galore
They are made on a CNC lathe with a bar feeder, so once set up it pretty much takes care of itself. You just need to change the inserts once in a while.
- markoteal
Re: Wheels galore
Wheely Mark, you can do better than that?
Re: Wheels galore
Still the back of the wheels look rough to me.
