Hi,
Video at:
https://youtu.be/0d1ZUBOV3hk
Regards Tony.
Ivor the Engine 'Ice on the rails'
- Tony Bird
Great work once again Tony, even the reindeer were helping!
Also watched "Building an engine shed" another marvelous piece of work. Interesting that the crowned pulleys are holding the belts dead true, bet that took some setting up. The walls and the individual brickwork just makes for a beautiful display piece.
- Tony Bird
Hi Grant,
Thank you for the compliment.
Also watched "Building an engine shed" another marvellous piece of work. Interesting that the crowned pulleys are holding the belts dead true, bet that took some setting up. The walls and the individual brickwork just makes for a beautiful display piece.
Oddly the pulleys can be quite misaligned and the belts slack and still work. The belt always seems to want to climb up the crown and stay in the middle of the pulley. If the belt is deliberately misaligned barely a half turn of the pulley will get it back in place.
Regards Tony.
Regards Tony.
