Dduallt Station building
Re: Dduallt Station building
Post by philipy » Tue Nov 23, 2021 1:01 pm
Yep, I agree, a first class job.
I dont think the plank gaps are overdone. They may be a tad overscale, but they show up and thats what is needed to give the effect and the human eye tends to ignore things like that.
SimonWood
Post by SimonWood » Wed Dec 22, 2021 5:05 pm
Returning to the forum after quite a few months... somehow with work and DIY my trains have been on the back burner! Anyway, I wanted to dive into this thread because I have discussed this build with Trevor (and now have his prototype!) and seen the model in situ on his line - where it looks fabulous. The build thread is fascinating, Trevor, and the stone and brickwork on the chimney absolutely superb.
Trevor Thompson wrote: Mon Oct 25, 2021 9:25 pm I have never tried printing in multiple colours before but this seemed like a valid reason to try it. So most of the sign was printed in white filament, and the embossed lettering and the surround printed in black filament:
I am really curious about this - I've seen the actual name boards but I hadn't realised the colour was the filament, not paintwork. So - how did you do this - do you have a new filament printer with dual nozzles?
Post by Trevor Thompson » Thu Dec 23, 2021 9:34 am
It is actually quite easy to change the filament mid print.
I got the idea after I realised that our printers had the ability to change filament mid print job. I had used it before when I was using up a reel of filament and watching when it got to the last 2 metres left.
When it is printing there is a set of icons along the bottom of the printers screen. The one on the right brings up some options. One is to turn on the light on the extruder, another is to change filament.
Using it at the end of a reel. You just need to leave enough sticking out to be able to pull it out - which means keep on looking at it as it prints. The machine tells you to pause printing first - you just confirm and it does it. It saves wasting filament.
In this case I watched it until it started to print the raised letters. A fine timing - which I have missed more than once. Then I changed filament. Hence the black lettering. I think it is sharper and crisper than I can achieve with paint.
sjrixon
Post by sjrixon » Thu Dec 23, 2021 10:07 am
Been quietly watching with interest. How did you do the bricks on the chimney? They worked really well..
SimonWood
Post by SimonWood » Mon Dec 27, 2021 10:44 am
Trevor Thompson wrote: Thu Dec 23, 2021 9:34 am It is actually quite easy to change the filament mid print.
Well this is doubly useful. I've abandoned prints where the filament has run out previously, as I didn't think it's be possible to change successfully. So that's a great thing to know for a start - and that it's easy enough to make it worth doing by choice, to print in two colours like this - excellent. Thanks!
Post by philipy » Mon Dec 27, 2021 12:09 pm
SimonWood wrote: Mon Dec 27, 2021 10:44 am I've abandoned prints where the filament has run out previously, as I didn't think it's be possible to change successfully.
Yes, I can confirm that it is possble to change filament in mid print although you do need to get the 2nd filament all ready, you only have a few seconds to feed it in.
Must admit I never thought of deliberately changing colours that way, though. I did once produce something with about 4 colours in it because it was only a test print and I had a load of odds and sods that were too long to throw away but not enough to use for one item!
metalmuncher
Post by metalmuncher » Mon Dec 27, 2021 12:39 pm
philipy wrote: Mon Dec 27, 2021 12:09 pm
Its a feature of some printer firmware to support an M600 command for changing filament - or be able to do it from the LCD screen while printing. I don't know if your printers have this feature, but it can be quite useful. The M600 command is put into your gcode file at the point you want to change filaments, e.g. just before the top layer, some slicers can do this for you like PrusaSlicer, or you can open up the gcode file and add the line manually before printing, or just use the LCD menu option at the right time.
The printer pauses, lifts & parks the head, and automatically fully retracts the filament out of the drive gear. It then prompts on the LCD for you to insert the new filament, and then it will purge until you tell it to stop. You can then get rid of the pile of purged filament at the nozzle with tweezers and tell it to carry on with the print. The advantage of the purge is that you get rid of the part of the print where you would have a mix of both filament colours, for example you wouldn't have an area of grey when switching from black to white filament.
Post by Trevor Thompson » Mon Dec 27, 2021 6:56 pm
sjrixon wrote: Thu Dec 23, 2021 10:07 am Been quietly watching with interest. How did you do the bricks on the chimney? They worked really well..
I measured an old brick - probably victorian - and made a "model" of a brick in sketchup. I then traced the drawing of the building to get the outline of the chimney, in 3 dimensions.
I copied the brick which I saved as a "component" and repeatedly pasted it on top of the chimney, moving the bricks around until I covered the outline. I worked out by trial and error that 2 bricks end to end were about the right size for the side of the chimney, and 2 bricks rotated 90 degrees with a brick between them were the same size.
So I literally placed the bricks in the right places with a slight gap between them - just as I would have if I were building a real chimney from bricks.
Finally I reduced the size of the base outline of the chimney by 10% in width and length - but left the height alone. This left the brick joints exposed as if the grouting was that type which leaves a slight gap between bricks. Exaggerated a bit of course but I wanted to define the edges of the bricks.
The stonework was done a bit differently. I photographed some stone walling and imported the photo into sketchup at the correct size. I then traced the stonework on top of the photo using that "Pen" which allows you to draw lines which follow where the mouse goes. Having a set of stones in outline I copied them and placed them on top of one side of the outline of the chimney. Then I pulled each stone 1mm to create the effect of stones joined by the same type of grouting - and deleted the stones which were outside the basic chimney outline.
I hope that makes it clear!
Trevor.
Perhaps I should add something about "nested objects". I often overlap components - as described above. If you use the Inspector software to identify faults in 3 D models it will identify a "nested objects" fault. If you look up that in the help section it says something about nested objects which ends with "sketchup will correctly export an stl file containing nested objects". So I ignore the warning, and the stl files have always printed correctly.
sjrixon
Post by sjrixon » Thu Jan 06, 2022 11:58 am
Thanks Trevor - That really works very well, I like that a lot!
I need to get started in sketchup at some point, just a Tinker Cad user at the moment and often hit the limitations.
Post by Trevor Thompson » Sat Jan 08, 2022 10:47 am
I am sure there is no "best" CAD software for our purposes. The 2016 version of Sketchup took me a long time to get used to, but I think I can do most things with it now. To the point where changing to another programme would set me back a long way!
I suspect you can get a long way using tinker cad.
Post by philipy » Sat Jan 08, 2022 9:55 pm
I agree with Trevor. I can do pretty much all I need with Sketchup, but it took some getting used to, and as I've said before, I simply can't get on with Tinker. It works in a very different way and is a whole new game to learn. If you look at what Steve and Rik can do with Tinker, I'd guess you would be better off staying with it and developing the skills for it, rather than starting afresh.
Post by ge_rik » Sun Jan 09, 2022 8:29 am
It seems to me that OpenSCAD is good for developing rescalable and easily modifiable small detailed parts - something which TinkerCAD isn't that good at. I might try investigating it, though it does look like the initial learning curve is almost vertical :shock:
SimonWood
Post by SimonWood » Mon Jan 10, 2022 7:34 pm
I agree with everyone - there are plenty of tools, but you spend so much time learning and doing the work, you don't want to throw away the time you've invested in it, unless you are sure another tool will enable you to achieve your ends appreciably faster!
ge_rik wrote: Sun Jan 09, 2022 8:29 am It seems to me that OpenSCAD is good for developing rescalable and easily modifiable small detailed parts - something which TinkerCAD isn't that good at. I might try investigating it, though it does look like the initial learning curve is almost vertical :shock:
I've been evangelical about OpenSCAD so you'll not be surprised I do think it is very good at that! Despite that, there are things it is not so good at, and sometimes it may be worth having more than one tool in your arsenal. For example I've been trying to relearn Blender (which I used to use for other purposes about 10 years ago). I think that Blender is very different from OpenSCAD so they cover very different needs. While I am getting on much faster with OpenSCAD for things like wagon and loco components, if I wanted to draw a chicken I suspect I'd still do a lot better in Blender.
Post by Trevor Thompson » Thu Jan 13, 2022 11:18 am
You will have to show me how to go about drawing a chicken in blender! I can’t see where to start at the moment!!!!
SimonWood
Post by SimonWood » Thu Jan 13, 2022 11:45 am
Trevor Thompson wrote: Thu Jan 13, 2022 11:18 am You will have to show me how to go about drawing a chicken in blender! I can’t see where to start at the moment!!!!
I'm not saying it would be a good chicken! I can make something that looks more like a Doctor Who monster right now... but I can see how I'd work on it... I did find the 3D Printing Professor's tutorials on Blender for 3D printing useful for learning how to approach it when your end is a real-life solid rather than an in-computer animation (he's also a Flashforge Adventurer 3 user!)
