I have recently acquired a Merlin Maestro but I'm having problems getting it to run. At this point I'm attempting to run it on compressed air and although it shows some signs of movement it almost immediately locks up. To me this suggests that the timing is wrong which probably is a result of at some previous time being assembled incorrectly. There is no adjustment on any the running gear or pistons or valve gear but solely depends on being assembled correctly. The only possibility I can see is that the pinning of the driven wheels can be out by 180 degrees i.e.they have to be pinned in the correct relationship to each other. I can also see that the original pinning holes which are clearly as original allow for one wheel crank pin to be 90 degrees in advance or retard of the other.
I would very much appreciate any help or advice from anyone who has actual experience or knowledge of the Merlin and particularly the Maestro assembley. This could be either pictures of both sides of a working Maestro with wheels in a fixed position or information of the crank positions in relation to the valve gear.
Merlin Maestro - Help Needed
Re: Merlin Maestro - Help Needed
Can I ask a question about the locos back cab sheet? is there a hole just above the buffer beam with a bras rod just protruding ?
if so this rod will have two notches in it they move your slide bars for forward or reverse, you can get it wrong the notch is set correctly for forward or reverse. They regulator is on a servo arm. The other way is a full rotation in the way of travel. Put water in it set fire, away you go.
Hi jimmytrains
Thanks for your reply. On my Maestro there is no protruding brass rod at the rear but I can understand what it does. My Forward/Reverse gear is activated with an RC servo which together with another servo activating the steam valve is how it would have been supplied new. I think the point you are making is that with the Forward/Reverse gear in the mid position there is no action from the steam cylinders so it does not run. Unfortunately that is not the problem with my engine as it fully engaged either Reverse or Forward motion. Thanks anyway for the suggestion.
After spending considerable time trying to understand why my Maestro will nor run I am still without success. I really would like to hear from someone who has a working Merlin Maestro for information on how it is setup. I am fairly sure that the problem is a a timing issue and as there are no actual adjustments that can be made to the semi Walschaerts valve gear it must depend on the relationship betwee the starboard and port crankpins on the driven wheels. I believe that original Merlin Locomotive Works may have simply use grubscrews to fix the relationship between the two driven crank pins but now as purchased they are pinned in position on the axles. It is therefore possible that they are not in the correct relationship. From information I have uncovered it seems that with the starboard crankpin at the 6 oclock position the port one shoul be at quarter to 12 oclock i.e. 180 degress and just before 360 degrees. Or should they be 180 and 360 or something else. Someone with a working Maestro should be able to tell me this please.
Or am I wrong and could there be some other reason why it doesn't run. Thanks for any help or suggestions.
The crankpins on a two cylinder engine should lead by 90 degrees. Convention holds that the starboard side leads the port on a railway locomotive.
Users browsing this forum: philipy and 0 guests
