andysleigh
Post
by andysleigh » Tue Dec 02, 2008 3:01 pm
Well, following the article in the recent SMT, i have decided to make a coal fired vertical boiler loco.
Its going to use a couple of old mamod cylinder that i have spare.
mhlr
- Retired Director
Post
by mhlr » Tue Dec 02, 2008 10:20 pm
I thought you were gunna use Wilesco cylinders?
andysleigh
Post
by andysleigh » Tue Dec 02, 2008 10:56 pm
mhlr wrote:I thought you were gunna use Wilesco cylinders?
i thought you would mention the cylinders (because they are mamods right)
Because i have two mamod cylinders spare, and they are smaller than wilescos, also can change directrion with a lever, not by pushing it.
This is a diffrent design, which is smaller than the previous one
mhlr
- Retired Director
Post
by mhlr » Tue Dec 02, 2008 11:00 pm
Right. Just wondered, as you're last design had Wilesco cylinders that u had spare.
SillyBilly
Post
by SillyBilly » Tue Dec 02, 2008 11:05 pm
If I ever have a go at one I'd deffiantley go for two upgrade mamod cylinders, that way you only have to buy the mamod frames, cut them in half, allready the holes for the shaft will be true, then you just have to bolt them on with some angle.
ACLR
Post
by ACLR » Wed Dec 03, 2008 7:16 pm
looks like a great project Andy
look forward to the progress
SillyBilly
Post
by SillyBilly » Wed Dec 03, 2008 10:54 pm
Having read the comments on the 16mm e-group, about the run-time, etc... I am thinking that with two cylinders the water comsumption rises considerably, you'd forever have the top-up bottle in your hand, because you'd want a lap from it atleast, the amount of water you'd be pumping in would cool the boiler=no steam=no blower=back to the electric blower=fail.
Go for the single cylinder, it's proven it'll work.
andysleigh
Post
by andysleigh » Wed Dec 03, 2008 11:14 pm
nope
i am sticking with two.
SillyBilly
Post
by SillyBilly » Thu Dec 04, 2008 1:16 pm
It's a big risk your taking, I hope it works for you.
alan2525
Post
by alan2525 » Thu Dec 04, 2008 3:16 pm
Looking at the size of the boiler and the inefficiency of the firebox, I would have thought it would struggle to supply the double acting cylinders with enough steam, especially the extra resistance from the upgraded cylinders with the much stiffer springs and o rings.
Maybe a little twin cylinder made from regular single acting ossies would work better? especially as it'd be suitably geared down and used with the grooved 'extra power' cylinders.
SillyBilly
Post
by SillyBilly » Thu Dec 04, 2008 4:11 pm
Might you not just aswell build it with one upgraded cylinder rather than messing around producing a two smaller cylinder unit which would probably have the same power output?
andysleigh
Post
by andysleigh » Thu Dec 04, 2008 5:31 pm
two cylinders looks better.
and if coal doesnt work , then it shall get a gas burner.
SillyBilly
Post
by SillyBilly » Thu Dec 04, 2008 5:36 pm
No matter what burner you put in it, it still won't be able to cope with the steam supply.
Endless, Nameless
Post
by Endless, Nameless » Thu Dec 04, 2008 5:40 pm
Do I get the impression a mixture of enthusiasm and sheer bloody mindedness may be overpowering engineering ability and quite possibly common sense here?
Or maybe I'm just cynical.
Either way, it's an interesting project and I shall be watching carefully.
andysleigh
Post
by andysleigh » Thu Dec 04, 2008 5:53 pm
SillyBilly wrote:No matter what burner you put in it, it still won't be able to cope with the steam supply.
so now your assuming that no burner will be able to supply enough steam for two oscillating cylinders????
SillyBilly
Post
by SillyBilly » Thu Dec 04, 2008 6:44 pm
No, read what I write properley, the boiler's water and steam capacity is likely to be insufficient to power two cylinders.
andysleigh
Post
by andysleigh » Thu Dec 04, 2008 8:02 pm
i did read it properley
you said "No matter what burner you put in it, it still won't be able to cope with the steam supply."
To me, that sounds like your assuming that no burner at all can supply enough steam.
And ok, i will use ONE cylinder, even tho i dont really want to, and it doesnt look as good.
andysleigh on Fri Dec 05, 2008 1:44 pm, edited 1 time in total.
pauly
Post
by pauly » Thu Dec 04, 2008 8:05 pm
I though coal burned at higher temperatures than gas so if a coal burner couldn't handle it a gas burner would be worse.
A steam propelled life-style.
made-in-england
Post
by made-in-england » Thu Dec 04, 2008 8:13 pm
from memory coal does not burn as hot but burns longer and with a more steady supply of heat. May be wrong and confusing it with somting else
SillyBilly
Post
by SillyBilly » Thu Dec 04, 2008 8:17 pm
andysleigh wrote:you said "No matter what burner you put in it, it still won't be able to cope with the steam supply."
To me, that sounds like your adduming that no burner at all can supply enough steam.
Because from what you wrote about changing the burner implied that a change in burner would improve the possibility of a steady steam supply.
