Roundhouse Millie top up system, sight glass and gauge
alan2525
Does anyone have any pictures of the Water top up system, Sight Glass and Pressure Gauge / Syphon fitted to the Roundhouse Basic Locos.
I was looking at my new Mille (Oily Rag's loco from these forums - Thanks Eric!) and figuring how best to fit these parts. I've got a 5mm sight glass with blow down, clack valve, whistle valve, whistle, pressure gauge etc that I want to fit, but wanted to have a look at the Roundhouse Parts to see if it's worth turning up a manifold or fitting roundhouse of fthe shelf bits.
Thanks in advance for any help!
The main issue seems to be lack of clearance underneath the loco for fitting the lower fitting for a sight glass.
SillyBilly
You don't need a clack valve unelss your putting an enotts or a hand pump on.
http://gardenrails.myfreeforum.org/ftopic593-0.php
MHLR has got some good photos here of his heavily upgraded Bertie (same thing really). If you asked Roundhouse you'd possibly be able to buy the pressure gauge siphon seperatley, personally I'd just buy the upgrades given that it'd be so much Quicker and easier.
Chris
alan2525
Cheers for the link! I wanted the additions to look a little nicer than the Roundhouse solution as the loco has an open cab, the roundhouse filler is fine for the Bertie but looks a bit ugly sticking out at an angle in my eye. Also I was thinking of putting an Enotts valve under the footplate to simplify refilling the loco. Plus I'll need an extra thread for attaching the whistle valve.SillyBilly wrote:You don't need a clack valve unelss your putting an enotts or a hand pump on.
I've designed a little Brass Manifold block which should do the trick and hopefully not look too ghastly! Also fancied fitting the sight glass I already have as it's a nice model engineering one with a proper tube off the drain and a little wax cast handle on the blow down valve!
SillyBilly
mhlr
- Retired Director
alan2525
