ESME Mk II
ESME Mk II
Tonight, I've started work on my partially built (bought on Fleabay) IP Engineering Lollipop Railcar. Unfortunately the previous owner (who I think may be a Forum member) had subscribed to the "use as little glue as possible" school of thought, with the result that a lot of it fell apart when I started on it! Still, it's all NEARLY in one piece again and the wheels, axles, gear and chain sprockets are all sorted.
Pictures tomorrow (maybe)
Made some more progress today - decided I didn't want a "flat" look and I'd already decided not to use the lights so I planked the body with planks from coffee stirring sticks, of which I have a LARGE stock!
More pictures and words at: http://www.mdlr.co.uk/loco12.html
- Steven.T
- Chris Cairns
The problem I found with my IP Lollypop Railcar is that the strip wood used is so small that it is difficult to get glue to take a proper hold.
Thus it remains in a fragile state until you get the roof on, but I've still got some painting & wiring to complete before the roof can go on.
What glue do you use Brian?
................... and to answer Dave, I'm doing a bit of all sorts! The ends will largely be painted Warning Panel Yellow, as the loco's going to be operating in an industrial environment. The sides are going to be green garden furniture stain, the the bulkhead behind the cab will be wood stained and the underframe and axle boxes will be painted!
The name and number plates have now arrived and I've attacked it with the weathering powder.............
It remains to be seen whether or not the matt varnish affects the finish.
More pictures at:www.mdlr.co.uk/loco12.html
- Chris Cairns
That has a very nice industrial look to it now Brian.
I have a similar Lollypop railcar which awaits finishing in my workshop. I notice you have mounted the 4 wheel drive chain with the same amount of slack that mine currently has. Does it run OK like that or would it benefit from having one more link removed from the chain (I intend doing that but I'm finding it difficult to get the shortened chain to join properly)?
It runs fine, and I couldn't get that link out, either!Chris Cairns:81345 wrote:I notice you have mounted the 4 wheel drive chain with the same amount of slack that mine currently has. Does it run OK like that or would it benefit from having one more link removed from the chain (I intend doing that but I'm finding it difficult to get the shortened chain to join properly)?
Thanks for the compliment, too!
Jerm
Users browsing this forum: No registered users and 59 guests
