Never judge a book by its cover - 'Train' G Scale stock
MTA
Post by MTA » Thu Apr 29, 2010 9:17 pm
A load of, what I first described to my boss as "...what looks like cheap and nasty G Scale stock", G scale rolling stock turned up today produced by a company whos name is not apparent.
It's all made in China, and the build quality isn't outstanding but is bearable and should withstand a few years good service.
When I saw the flat bogie wagons I thought "Ahh, with a bit of work they'll look good behind my Merlin Beck" as all the wagons are based on continental practice, the RhB in particular.
The flat wagons, which is what I'm reviewing, come as a pack of two and for £29.99 at the full RRP each flat wagon works out at roughly £15. They come in a choice of four colours; yellow, green, grey and brown. I went for brown, as it will look good behind my Merlin after its refurbishment.
My plan was to whip the wheelsets out and replace them with long axle 32mm ones like the ones GRS and Brandbright supply. On closer inspection, the wheelsets fitted have spacers moulded on the back with a metal axle running through them. So I can just file the spacers to suit without going to a lot of expense and effort :D I will have to check the flanges though, as they look a bit big.
Also apparent in the pic, is that there's quite a bit of moulded in detail such as braking equipment.
The LGB pattern couplings easily unscrew from the bogie which again is a nice moulding and is quite close to the L&B diamond frame type. Another nice feature is that the bogies have built in compensation, which I didn't expect and originally thought was slip shod build quality!
The centre buffers simply clip in, so I'll be removing these and fitting Accucraft square head choppers in their place.
The body is another clip in arrangement, with the sides being seperate from the ends. So you could have a flat wagon with ends, or a plain old flat wagon. Or, with some surgery, a stake wagon.
Also available are verandah brake vans (£29.99) in grey, yellow, green and brown and a tank wagon with a working handwheel and filler plus handwheel drain valve. To get around copyright they've put the word 'Shall' on the side instead of 'Shell' :lol: The tank wagon is £22.49.
Post by 90733 » Thu Apr 29, 2010 9:21 pm
Not the best build quailty but I dont mind the look of them, especially since I generally don't like forgien wagons. :D
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Thu Apr 29, 2010 9:26 pm
Hey thats fantastic value for money that is! I am interested to follow this one... How are you modifying them?
MTA
Post by MTA » Thu Apr 29, 2010 9:36 pm
Mr. Bond of the DVLR wrote:How are you modifying them?
Regauging; changing the couplings, might rub off some of the lettering, add vacuum pipes and that's about it.
If I feel brave I might weather the underframe and running gear.
Post by laalratty » Thu Apr 29, 2010 9:45 pm
They look pretty good and are good value at that price. LGB wagons have the same wheel and axle arrangement and so can be reguaged the same way
Endless, Nameless
Post by Endless, Nameless » Thu Apr 29, 2010 9:59 pm
They are made by Newquida. The reason they are so detailed for the price is because they are reverse engineered LGB. There was a lot- and I mean a lot- of a fuss kicked up about these when they came out and some of it turned quite nasty. However the relevant authorities have investigated the wagons and all has been confirmed above board.
They aren't the best quality of materials in the world but they ain't bad- the coaches are certainly very good for the money and look excellent with a coat of paint. I've seen blood and custard and brown and cream versions, but I think royal blue and cream would look ace on them. The vans are very European and the bogie wagons need a bit of work but the tankers could go into service with just a couple of coats of matt black- at less than £20 a pop.
Endless, Nameless
Post by Endless, Nameless » Thu Apr 29, 2010 10:02 pm
Oh, wheels are LGB profile and hence the flanges are too big for Peco 32mm track. You'll have to turn them down a bit.
mhlr
Post by mhlr » Fri Apr 30, 2010 12:32 am
Not a bad find! Will look excellent with a bit of Anglicising.
pauly
Post by pauly » Fri Apr 30, 2010 12:47 am
Annieshalts got a SHALL wagon :lol:
A steam propelled life-style.
taliesin001
Post by taliesin001 » Fri Apr 30, 2010 5:05 pm
Very nice :D
MuzTrem
Post by MuzTrem » Fri Apr 30, 2010 5:30 pm
Looks line an interesting range. Does anyone have any photos of the carriages?
Endless, Nameless
Post by Endless, Nameless » Fri Apr 30, 2010 6:41 pm
http://www.storacingproducts.com/g-scal ... rains.html
Is most the range.
The loco is pretty pants by all accounts; not worth the asking price anyroad- but the rest ain't bad.
Post by Narrow Minded » Fri Apr 30, 2010 7:07 pm
Mmmh! Those coaches look almost "Pickering - esque" ;)
But I tell you what, I can't find pairs of 45mm bogies cheaper than the price of those wagons :shock:
mhlr
Post by mhlr » Fri Apr 30, 2010 9:56 pm
Narrow Minded wrote:Mmmh! Those coaches look almost "Pickering - esque" ;)
I was thinking that. With a bit of bashing and painting, you could make them look quite good!
Hancockshire
Post by Hancockshire » Fri Apr 30, 2010 11:03 pm
WOW!! finally some rolling stock I can afford(before you say, I've lost my job thanks to the bosses psycho wife who wan't to kill the new manager)
mhlr
Post by mhlr » Fri Apr 30, 2010 11:14 pm
Don't forget to add the price of some 32mm wheelsets on... but they aren't too much.
Hancockshire
Post by Hancockshire » Fri Apr 30, 2010 11:29 pm
As long as I don't have to trade in a leg for them all. Mind you, I have a spare set of regauged Ip wheels. I had ordered wheels for my GS6 & two more axles for a future project. Trouble was that I was given 45mm wheels. I thought that boiling water would soften the plastic insulation thingies & it worked! Long axled wheels for use. I want the vans the most
Endless, Nameless
Post by Endless, Nameless » Sat May 01, 2010 11:28 am
Have a browse round G scale central Pete. Someone has done just that, including doing one as a brake/ parcels coach IIRC- they are brilliant. Another chap has done them- very, very neatly- in blood & custard- he also has a 2-tone green LGB diesel and Brunswick green Piko railbus.
The pair of wagons are ridiculously good for the money.
pauly
Post by pauly » Sat May 01, 2010 12:35 pm
Have you heard the sound effects for the Newquida Bullet train!
F**king hillairious!
http://www.youtube.com/watch?v=9wLqMAqTpvE
when I was a little kid I had a toy train that had a push button sound feature that used exactly the same sound board.
cheap!!!!!!!!!!
PCLR
Post by PCLR » Sat May 01, 2010 12:45 pm
hahaha what the f**ks that about, well done paul :lol:
