Rail chairs
TTgardenrail
Rail chairs
Does anyone know of a supplier of rail chairs for the old code 330 brass rail please. I have a lot of brass rail and wish to make my own 32mm narrow gauge track. Thank you. Tony
Re: Rail chairs
Hi Tony, are you talking about the brass rail supplied by Tenmille about 40 years ago? I have no idea about the 330 code you mention but the rail was available in both flat bottom and bullhead section.
If so, the chairs were moulded plastic and I might be able to help.
TTgardenrail
Re: Rail chairs
Thank you , the rail was originally fitted into accucraft plastic sleeper units set at 45mm. I wish to change to 32mm gauge track and have an awful lot of this brass rail to use up if possible . I have attached some photos if it helps? Tony
- Attachments
- 20230801_161118.jpg (3.13 MiB) Viewed 7074 times
- 20230801_161048.jpg (3.8 MiB) Viewed 7074 times
- 20230801_161030.jpg (2.08 MiB) Viewed 7074 times
Re: Rail chairs
Sorry Tony, but those dimensions are way bigger than I imagined. Perhaps spikes would do the trick?
TTgardenrail
Re: Rail chairs
Thank you for your reply , I now believe my brass rail to be code 332 section not 330! Please see this link to explain. https://www.gardenrailways.co.uk/category-45.html . Slowly unravelling the identity and possibly a solution !
Be a shame not to use it to make my own 32mm gauge track!
