Hard drive enclosure
Post by ge_rik » Tue Jan 11, 2022 2:07 pm
I realise that this is probably Old Hat for many of you, but just in case it isn't.
I've just invested in a couple of hard drive enclosures/caddies for drives taken out of redundant laptop computers:
They cost me the princely sum of £5.99 each (inc postage) from a UK seller on eBay
https://www.ebay.co.uk/itm/304043082956
It's usually dead easy to extract the hard drive from a laptop - 2 - 4 screws holding a flap on the underside of the laptop and the drive unclips. I'd suggest doing this anyway before dumping any old computer. It's then simply a case of slotting the drive into the caddy, replacing the lid and plugging the USB lead into the back of it - et voila, one external hard drive (assuming of course that the reason the laptop failed wasn't because the hard drive had failed!).
I've been able to extract some music and photo files off the drives before reformatting them - though I'll not save anything critical on them in case they give up the ghost.
To my mind, it's worth the investment of £6.00!
PS - The most difficult part was trying to figure out how the lid comes off the caddy - it slides to the back - the lid is uppermost when the electronic components are facing downwards - as in the photo
Re: Hard drive enclosure
Post by -steves- » Tue Jan 11, 2022 2:32 pm
One thing to note is that there are 2 types of caddy and 2 types of hard drive.
If it's a more recent machine then it's likely to SATA, older ones are likely to be IDE. If it's a full length connector full of a dual bank of pins or holes that's IDE, SATA is not quite full width and has a more unique type of connector.
Been using these types of hard drive enclosures for donkey's year now and they are great for transporting or backing up data, as long as it's just a back up and not the only backup. Hard drives fail, A LOT! :lol: :thumbup:
Post by ge_rik » Tue Jan 11, 2022 2:49 pm
-steves- wrote: Tue Jan 11, 2022 2:32 pm One thing to note is that there are 2 types of caddy and 2 types of hard drive.
I found my two drives were clearly labelled SATA and slotted in without a problem.
I had less success with the DVD ROM/ CD RW enclosure. Completely different plug socket arrangement. I've sent off for another which will hopefully be different. The descriptions don't show the connectors clearly unfortunately.
Post by Old Man Aaron » Tue Jan 11, 2022 3:38 pm
Great idea! Never knew one could buy those. Certainly beats paying a technician $100 to transfer data between drives.
Post by -steves- » Tue Jan 11, 2022 3:54 pm
ge_rik wrote: Tue Jan 11, 2022 2:49 pm
The reason for that is that there is not the same agreed standard like there is for HDD's, even in the same company sometimes, though some do exchange and meet a standard, many do not. Once you get started on the front panel, forget it, that's a minefield and is just about different on every model.
There are other connectors as well for hard drives, but those are mainly for commercial use like fibre connectors etc.
Palmerston
Post by Palmerston » Tue Jan 11, 2022 3:56 pm
I just opened a parcel just moments ago which contains a hard drive enclosure....
The drive isnt recognized by my laptop, it just makes clicking noise, plugged in the desktop and its readable.
Live steam on 45 & 184mm, battery 45mm only.
Palmerston
Post by Palmerston » Tue Jan 11, 2022 3:58 pm
and a dual power USB cable (the red connector is power only)
power from 2 USB ports to the drive, to be sure enough power is available as i got the message "USB drive not ready"
Palmerston
Post by Palmerston » Tue Jan 11, 2022 4:25 pm
7€ for the enclosure and 4.60€ cable.
Jimmyb
Post by Jimmyb » Tue Jan 11, 2022 5:08 pm
There are also 2 sizes of hard drive, a laptop usually 2.5" and desktop 3.5", then there are IDE and SATA, but two type of SATA, SATA II and SATA III (6gb), so these currently out there 6 types of hard drive all with different interfaces.
Palmerston
Post by Palmerston » Tue Jan 11, 2022 5:45 pm
IDE is very old 10-15 years last build
Sata 1-2-3- refers only to the data transferspeed. Pinlayout and cables are the same and the drives are downwards compatible so no problems here!
Jimmyb
Post by Jimmyb » Wed Jan 12, 2022 8:05 am
Palmerston wrote: Tue Jan 11, 2022 5:45 pm IDE is very old 10-15 years last build
I stand corrected :)
Post by ge_rik » Wed Jan 12, 2022 8:46 am
-steves- wrote: Tue Jan 11, 2022 3:54 pm
The reason for that is that there is not the same agreed standard [for DVD/CD drives] like there is for HDD's, even in the same company sometimes, though some do exchange and meet a standard, many do not. Once you get started on the front panel, forget it, that's a minefield and is just about different on every model.
Thanks for that info, Steve. If the second case isn't any good, I'll give up. Just checked and complete USB DVD RW drives aren't much more expensive than enclosures anyway, so I'll cut my losses, sell the empty enclosures and buy a new complete drive. (My new laptop doesn't have a built in DVD RW which I still need for several reasons)
Post by -steves- » Wed Jan 12, 2022 9:32 am
ge_rik wrote: Wed Jan 12, 2022 8:46 am
I am in the same boat. My laptop has no internal optical drive and I have to use a USB CD/DVD drive / recorder.
Post by -steves- » Wed Jan 12, 2022 9:49 am
Jimmyb wrote: Tue Jan 11, 2022 5:08 pm
FYI there is also a 1.8" HDD as well, but that is a SATA connector only, hence I didn't mention it as it fitted into the two connectors mentioned.
Post by -steves- » Wed Jan 12, 2022 9:50 am
IDE may well be old, but I still have a box of them in drive enclosures that I use as external storage from time to time to move data around, all be it, not very much capacity. Not sure how much longer they will work as some of those are at least 20+ years old, lol :lol:
