Water crane
Water crane
Post by ge_rik » Sat Jun 10, 2017 6:18 pm
After over ten years of operation, I decided it was time locos on the PLR were given the opportunity to quench their thirsts and so a water tower and water crane have been added to Beeston Market station. The tower was constructed from an old Model Town kit but I felt the crane was something I could tackle myself.
Ingredients:
  • main column = 5mm wooden dowel
  • collars on the column = plastic tubing and barrel from a cheap biro
  • base of column = tap washer
  • valve housing = 10mm wooden bead
  • valve = casting from Cambrian Models
  • cap on column = end of plastic test tube
  • joints on column = metal washers
  • counterweight = end of plastic party 'blower'
  • arm = 4mm wooden dowel covered in 5mm plastic tube
  • support for arm = brass rod
  • hose - heatshrink tubing
It's not a perfect representation of the real thing, but seems to look the part.
It still needs to be weathered and positioned at the end of the platform (weather permitting).
More info and other developments on my blog - https://riksrailway.blogspot.co.uk/2017 ... rt-68.html
Re: Water crane
Post by Peter Butler » Sat Jun 10, 2017 9:21 pm
Very convincing Rik, nicely made and a most useful accessory.
Re: Water crane
Post by LNR » Sun Jun 11, 2017 6:00 am
Great job Rik, and it sounds like it used up plenty of odd bits around the house. As modellers we need to see what things can be, as apposed to what they are.
Re: Water crane
Post by philipy » Sun Jun 11, 2017 6:51 am
Looks good Rik.
An excellent example of using odd bits to make a representation of something, as we discussed some while ago.
Re: Water crane
Post by ge_rik » Sun Jun 11, 2017 8:32 am
Thanks chaps. I do enjoy the challenge of solving constructional problems by re-purposing bits and pieces - and of course saving money at the same time. The valve on the water tower was constructed in a similar way.
Re: Water crane
Post by tom_tom_go » Sun Jun 11, 2017 10:02 am
Heatshrink as the hose, brilliant!
Re: Water crane
Post by Soar Valley Light » Sun Jun 11, 2017 7:19 pm
Hello Rik,
What a lovely job you've made of this. It looks well proportioned and well engineered, most of all it looks functional. Well done.
Re: Water crane
Post by LNR » Mon Jun 12, 2017 12:36 am
Gee! that last pic. could be 1:1 scale.
Re: Water crane
Post by ge_rik » Mon Jun 12, 2017 6:01 am
LNR wrote: Mon Jun 12, 2017 12:36 am Gee! that last pic. could be 1:1 scale.
Thanks Grant - that's praise indeed from someone with your eye for detail
Re: Water crane
Post by jim@NAL » Mon Jun 12, 2017 6:31 pm
that's rather brilliant
markoteal
Re: Water crane
Post by markoteal » Mon Jun 12, 2017 9:36 pm
Brilliant - as usual - I love the way you have taken lots of 'bits' and created something so right! - and as Tom said, the heat shrink - genius!
Boustrophedon
Re: Water crane
Post by Boustrophedon » Sat Jun 24, 2017 12:41 pm
I have a desire to build a working water tower and water crane that I can actually fill the locos from. I think it's going to be fun to make.
Re: Water crane
Post by ge_rik » Sat Jun 24, 2017 12:46 pm
Boustrophedon wrote: Sat Jun 24, 2017 12:41 pm I have a desire to build a working water tower and water crane that I can actually fill the locos from. I think it's going to be fun to make.
Sounds interesting. Will the water have to be pressurised in some way?
Boustrophedon
Re: Water crane
Post by Boustrophedon » Sat Jun 24, 2017 1:06 pm
ge_rik wrote: Sat Jun 24, 2017 12:46 pm
I was kinda hoping gravity would work. Wont fill through a Goodall valve obviously.
markoteal
Re: Water crane
Post by markoteal » Sat Jun 24, 2017 1:49 pm
I like it - this will be a good one to watch!
Re: Water crane
Post by FWLR » Tue Sep 12, 2017 7:40 am
A great model Rik, brilliant. :thumbup: :thumbup: :thumbup:
